Robbiejc843
Unable To Debond Bluetooth Devices On Sony Dab
I have recently bought a Grand C-Max 1.6 Tdci Titanium 2011. I've tried to bond my phone to the bluetooth but it says that there is not enough room and to delete them via the phone menu. I go through the procedure in the manaul but when I try to select phone the display shows that there are no BT devices! Can anyone help without the need to go back to the dealer?post-56871-0-17415700-1406848833_thumb.jpost-56871-0-78415100-1406848836_thumb.j
Clive,
Unfortunately that didn't work even after disconnecting for over an hour!
Regards Rob
Hi Rob, did you get it sorted? You could also try removing the fuse for the sync, have a look in the manual, I had a similar prob with mine and this did the trick! :-D
