Robbiejc843 Posted July 31, 2014 Share Posted July 31, 2014 I have recently bought a Grand C-Max 1.6 Tdci Titanium 2011. I've tried to bond my phone to the bluetooth but it says that there is not enough room and to delete them via the phone menu. I go through the procedure in the manaul but when I try to select phone the display shows that there are no BT devices! Can anyone help without the need to go back to the dealer? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 31, 2014 Share Posted July 31, 2014 Disconnect the battery for 20 minutes. Sent from my SM-G900F using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Robbiejc843 Posted August 1, 2014 Author Share Posted August 1, 2014 Cheers Clive. I will give that a try :) ! Regards Rob Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 1, 2014 Share Posted August 1, 2014 Let us know how you get on. Sent from my SM-G900F using Ford OC mobile app 1 Quote Link to comment Share on other sites More sharing options...
Robbiejc843 Posted August 1, 2014 Author Share Posted August 1, 2014 Clive, Unfortunately that didn't work even after disconnecting for over an hour! Regards Rob Quote Link to comment Share on other sites More sharing options...
Robbiejc843 Posted August 7, 2014 Author Share Posted August 7, 2014 Back to the dealer it is then!!!! Just hope they don't want paying for it!!!! Quote Link to comment Share on other sites More sharing options...
DanDanFiestaMan Posted September 6, 2014 Share Posted September 6, 2014 Hi Rob, did you get it sorted? You could also try removing the fuse for the sync, have a look in the manual, I had a similar prob with mine and this did the trick! :-D Quote Link to comment Share on other sites More sharing options...
