FOCA Posted August 29, 2014 Share Posted August 29, 2014 Wow just says lynx doesn't say euro 4 or anything, It may not have an egr fitted mate ill research it further tomorrow Chances are it has an EGR valve - http://www.ebay.co.uk/itm/Ford-Focus-Mk1-Mk2-1998-2004-1-8-TDCI-EGR-VALVE-MANIFOLD-2M5Q-9424-CA-/360865881157?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5405485c45 Most cars have them by 2000 1 Quote Link to comment Share on other sites More sharing options...
FOCA Posted August 29, 2014 Share Posted August 29, 2014 isnt the Wynns step a bit of a mine field? Im not an expert at all but I've been reading all sorts and the general consensus has been, if you have a new car or its had plenty and regular oil changes then its fine, but if its a bit long in the tooth with unknown oil changes then doing it may give you more hassle as it breaks up all the old crap, which may either lead to leaks or more likely block things up as it comes off and floats about. I read somewhere that if your going to do it on poorly looked after engines or long oil change intervals, then the first time you'll need to clean it change it, run it and repeat it 2 or 3 times to help reduce the chance of crap getting in to places you don't want it, suggestion was to use cheap oil first for a couple of hundred miles then on the final go put in the good stuff. Using it after should be fine so they say... We have to be clear that we are talking about fuel or oil additives, you sound like you are talking about oil additives Lenny is talking about fuel additives (obviously 2 different things) Fuel additives such as Winnes cannot clean the EGR valve, or inlet manifold, they can only clean the fuel lines and injectors, combustion chamber etc, the fuel goes nowhere near the EGR valve or inlet manifold on a direct-injection diesel, to clean the inlet manifold (or EGR valve) you need to take it off and clean it properly 2 Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted August 29, 2014 Share Posted August 29, 2014 So does that make using the oil tank cleaner a nono then? Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 2, 2014 Share Posted September 2, 2014 Thanks for all the help guys blanked my EGR valve last night its at the back of the engine awkward to do but worth it seeing an immediate improvement cant Believe the benefit from a piece of metal Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted September 2, 2014 Share Posted September 2, 2014 .. 1 Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 2, 2014 Share Posted September 2, 2014 Yeh im just deciding what chip to get its getting colour coded with some dents removed and sprayed up got it for £150 so im pleased with that aswell as the service its going to have myt get the engine steam cleaned also Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 2, 2014 Share Posted September 2, 2014 Friend of mine has got a 2.0l hdi 206 think it would benefit him having the egr blanked ? Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted September 2, 2014 Share Posted September 2, 2014 We have to be clear that we are talking about fuel or oil additives, you sound like you are talking about oil additives Lenny is talking about fuel additives (obviously 2 different things) Fuel additives such as Winnes cannot clean the EGR valve, or inlet manifold, they can only clean the fuel lines and injectors, combustion chamber etc, the fuel goes nowhere near the EGR valve or inlet manifold on a direct-injection diesel, to clean the inlet manifold (or EGR valve) you need to take it off and clean it properly Aye, sorry I was meaning the oil in that post, the fuel additives are amazing though, I used some AR6400 to 3/4 of a tank, unbelievable difference to the noise it makes and a noticeable difference with mpg and response. I really cant begin to describe how much of a difference this makes to the sound of the engine, if its sounding like a tractor the injector cleaner can sort it. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted September 2, 2014 Share Posted September 2, 2014 .. Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 2, 2014 Share Posted September 2, 2014 Mine wasnt easy egr was at the back i had to get the 1.8 most awkward one but il upgrade the air filter wen i can just bought a Halfords own one for now Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 2, 2014 Share Posted September 2, 2014 My air pipe wasnt even attatched to the box so the extra air pressure that has been escaping from the engine has been stopped Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 2, 2014 Share Posted September 2, 2014 My air pipe wasnt even attached to the box so the extra air pressure that has been escaping from the engine myt of been causing the low power ive been having now ive cleaned the air box clamped the pipe on and a new filter it ran better and blanking the EGR aswell it feels loads better cant wait to give a good clean through and service it should run alot smoother Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 2, 2014 Share Posted September 2, 2014 Yeh doing it saturday guna try and get the diesel addivite seen it on eBay Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 2, 2014 Share Posted September 2, 2014 Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 2, 2014 Share Posted September 2, 2014 Can I ask this: if u blank the EGR what knock on effect does it have in terms of service intervals, will I need to change the air filter & oil filter more regularly i bought this EGR blank http://m.ebay.co.uk/itm/161342021666?&txnId=1144207741006 Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 3, 2014 Share Posted September 3, 2014 Hey guys are there any other upgrades I can make to my focus to make it run smoother or faster new parts new pipes exhaust ect so any and all ideas welcome Sent from my iPad using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted September 3, 2014 Share Posted September 3, 2014 .. Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 3, 2014 Share Posted September 3, 2014 Filters getting changed Saturday il take a look an exhaust place and I'm currently shopping for a chip also Sent from my iPad using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Kye Posted September 3, 2014 Share Posted September 3, 2014 Can anyone tell me where the EGR valve is on the 2.0 TDCi on a Mk 2.5 at all? At the front I think I have read? 1 Quote Link to comment Share on other sites More sharing options...
Damon Cook Posted September 3, 2014 Share Posted September 3, 2014 Not sure it helps but I have. Mk1 and I just followed the pipe from the inter cooler and I found it mine was at the back of the engine Sent from my iPad using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 3, 2014 Share Posted September 3, 2014 I've got the 1.8 Tdci (Endura) engine and I'm having difficulty finding where the blank slips into. There's 2 places that it could go Quote Link to comment Share on other sites More sharing options...
Kye Posted September 3, 2014 Share Posted September 3, 2014 Cool beans. Thanks. I've only got the one plate so will go for the exhaust side of the valve. I guess that is the idea and/ or the only place the plate will fit. Quote Link to comment Share on other sites More sharing options...
