AJRTDDI
What Best Way To Fix This Bodywork Mess
10 posts in this topic
I was sanding down my car for respray for prep and I found this
It was full of paper and bodyfiller, I can't afford a whole new rear quarter I have brought a new rear arch to weld in but the door jam part will be hard. Any ideas ?
post-48488-0-82216800-1406980765_thumb.j
I would do a bit of plate welding, get a mate who has a welder just to weld a bit of sheet metal on to that then sand it down so it's nice and smooth
Hope this helps
Thanks,
Lewis Watson-Thompson
I can weld fine just idk how I'm gonna get the same shape without using a lot of bodyfiller
Sent from my HTC One X using Ford OC mobile app
Where should I weld a plate of steel when arch is cured
New arch
So no ideas about getting the right shape. How about fiberglassing?
I would be making that sort of repair out of several bits of metal. Using card to make templates, Sellotape then together if you think you can get a bigger section out of one piece of metal. Rolling a small section of metal should be easy enough to match that I would think.
I'll do alittle work and update with photos
I replaced the panel on arch just alittle more tidying rock. Found jacking points was also shot
Update pics
