Nicky2kuk
Trim Around Number Plate
3 posts in this topic
Can anyone help? I am trying to find out what the trim around the number plate on the bumper is called? We've been searching for it but can find anywhere. Also if this part is glued on as we can't seem to get it offpost-56674-140714869471_thumb.jpg
It is part of the sports pack bodykit and is basically just an alternative grill.
It is held on with two screws and then it has the lower front splitter bonded across the lower lip of it.
Why are you trying to remove it? It's a really rare & expensive part and will break easily.To remove it you have to apply heat to melt the glue on the lower splitter and peel that away first - which will probably damage the paint on it meaning you need to get it repainted....
It's cracked from the previous owner so just want to replace it so it looks better. Might just see if it can be repaired as it is. Thanks for ur comment
