Ids
25 replies to this topic
#16 Nukeybrown
Nukeybrown
    Member
  • Budding Enthusiast
  • PipPip
  • 14 posts
  • Name: Anthony
  • Ford Model: Fiesta mk7
  • Year: 2009
Posted 10 August 2014 - 08:27 AM
Right, headliner kinda off at the front , followed the wires back over and no white plug or even black & yellow wiring in the wiring going to the headlining , took stereo out had a look at connections etc to see if I could splice into the wiring for mic but cannot see any wiring of that colour in the plugs not even sure where the mic would originate . Heeeelllppp
Have something to contribute?
#17 footycards.com
footycards.com
    Newbie
  • Pip
  • 9 posts
  • Name: Simon
Posted 10 August 2014 - 08:51 AM
Maybe there isn't one there, ford do stuff like that, but as you have another loom you have no problems.
The two wires came directly out of the back of your usb module, start there, does your car / spare loom have back and yellow coming out of the bluetooth plug ? Are they the same ?
#18 footycards.com
footycards.com
    Newbie
  • Pip
  • 9 posts
  • Name: Simon
Posted 10 August 2014 - 09:10 AM
heres a pic of the loom from elsewhere off this forum which shows what your looking for, just follow from the bluetooth end
#19 Nukeybrown
Nukeybrown
    Member
  • PipPip
  • 14 posts
  • Name: Anthony
  • Year: 2009
Posted 10 August 2014 - 12:05 PM
Right found the 2 wires yellow & black coming out of the bluetooth module , only have a ex parrot mic to try but not working. Tested the yellow & black and there is definitely voltage in the wires but head unit not responding to speach. When you speak I'm guessing on screen the bar under voice control fills up as you speak if that makes sense? It isn't like so it's obviously not picking up. Will order the proper mic and then retry again another day. Not gonna put the mic in the headlining gonna put it where yours is. Can't really do much more until I get the proper mic really.
#20 Nukeybrown
Nukeybrown
    Member
  • PipPip
  • 14 posts
  • Name: Anthony
  • Year: 2009
Posted 10 August 2014 - 12:37 PM
Anyone know the best or any place in the uk to buy microphone or is it a case of going direct to ford
#21 gingertom
gingertom
  • 90 posts
  • Name: Dave
  • Ford Model: Fiesta ST2
  • Year: 2014
Posted 11 August 2014 - 11:48 AM
I did the retrofit Bluetooth mod in my 2010 zetec s
there is a separate loom which connects to the Bluetooth main loom by the base of the a pillar and is routed up the a pillar and across the headlining.
I bought the plastic headlining trim which houses the mic. You have to cut out the headlining to fit
#22 Nukeybrown
Nukeybrown
    Member
  • PipPip
  • 14 posts
  • Name: Anthony
  • Year: 2009
Posted 11 August 2014 - 10:10 PM
Thanks for that, my car unfortunately my car doesn't have the separate wiring up the a pillar to the headlining , I've ordered the mic direct from ford picking it up tomorrow morning , but it's a seperate unit that will be mounted on the drivers pillar £38.43. Let's hope it works. Fingers crossed.
#23 gingertom
gingertom
  • 90 posts
  • Name: Dave
  • Year: 2014
Posted 12 August 2014 - 08:51 AM
My car didn't have the loom, I had to order it separately. Hope your solution works
#24 Nukeybrown
Nukeybrown
    Member
  • PipPip
  • 14 posts
  • Name: Anthony
  • Year: 2009
Posted 12 August 2014 - 10:26 PM
All working good now, so must need the ford mic to work, properly £38 for a mic I think is expensive but it all works fine and is better than cutting into the headlining etc. didn't need extra looms etc as the 2 wires coming out of the bluetooth unit connected directly to it.
All I need to do now is remember all the commands.
Thanks for everyone's help
#25 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 17,380 posts
  • Name: Clive
  • Year: 2015
Posted 12 August 2014 - 11:31 PM
http://support.ford....nc-myford-touch
#26 footycards.com
footycards.com
    Newbie
  • Pip
  • 9 posts
  • Name: Simon
Posted 13 August 2014 - 08:41 AM
Awesome, Im glad your sorted buddy, and yes that Mic is a much better solution than hacking the headlining out.
:D
Not what you're looking for?
