scottyrb
Fiesta St 2 180 Plastics
They literally just pull off, start from one corner and pry it away then give thema good tug and the tabs will pop out.
I'm pretty sure it is yeh, definately the case with the other trim levels because I've done it on my zetec s. Not got my st-3 yet so can't tell you :( but I'm sure it's the same ? can't see it being bolted or screwed in.
A way to check is turn your wheel to full lock and undo the two screws holding your wheel arch in, move it out the way and look in too see behind the fog light plastics :)
