AJRTDDI
Mk4 St170 Turbo Starter Issue.
12 posts in this topic
I was wondering what I can do about my starter. I'm using a RS turbo gearbox. The starter is blocked by the 2 part sump. Can the alloy be cut?
Sent from my HTC One X using Ford OC mobile app
I'm guessing it will be safe to cut off?
I don't have any experience of the situation your talking about but perhaps we might be able to help if you could post up a picture?
Should be safe to cut off ? Guessing no one else as had any problem ?
The more metal you take off, the weaker it gets, no-one knows how much you can take off - untill it breaks - if you could re-enforce it in some way that would help - i take it the starter clears the sump?
Being as the cuts aren't by the bolts it shouldn't weaken it much ?
I havnt cut it yet myself to see if the sump hits. Trial and error I guess. I have some welding todo first tomorrow so I'll find out in few days
With these sort of things you have to be really careful/ must know what you are doing -
The casting is designed with webs etc (the triangular shaped fins/ corner pieces) some of which have been cut off - that will weaken it, also, the smaller contact area can mean the block may flex realative to the g-box - looks like you have cut the boltholes off - unless i am missing something?
Has this conversion been done before/ are there adaptor plates available? (for between the block and bell housing/ g-box)
As far as I'm aware the bottom bolt holes was used with 6 speed box. Maybe new holes are tarpered up higher for the rs box. Have the webs been added for strength or redesign of rear starter I do not know.
The pictures are from another build. I currently have mine intact
I'll update the thread tomorrow about the gearbox bottom bolts. With some pics
See if you can find out how they did it in the other build, like if it is from a forum, join and contact the owner/ builder, they must have already have found solutions to these problems
It was from a website index page. They cut the marked parts on the pictures so I guess it's safe
