Focus Radio Problems
6000 CD aux bluetooth
25 replies to this topic
#16 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,619 posts
  • Name: Clive
  • Year: 2015
Posted 16 August 2014 - 05:28 PM
There you are then ;)
You learn something new every day. :D
Have something to contribute?
#17 mrjudderman
mrjudderman
    Newbie
  • Budding Enthusiast
  • Pip
  • 8 posts
  • Name: Josh
  • Ford Model: Focus
Posted 16 August 2014 - 05:47 PM
I tried the update (thanks!), but the stereo did not respond to the usb being inserted, before or after switching the ignition on.
I've gone and taken the Nokia bluetooth box out to see if there's anything I can do with that. the sticker on the box describes it as "Bluetooth voice connectivity with usb" so it seems to be the correct type of module, but it may be defective
#18 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
  • Ford Model: Focus Zetec S 1.6 TI-VCT
Posted 16 August 2014 - 05:53 PM
is it a nokia or novero? thought only novero had usb. If the usb connector on the module is standard micro usb (was on mine) try a different cable directly into the module.  Could be your current socket./cabling to the socket that has a problem.
#19 mrjudderman
mrjudderman
    Newbie
  • Pip
  • 8 posts
  • Name: Josh
  • Ford Model: Focus
Posted 16 August 2014 - 06:14 PM
It's Nokia - one of these:
It's pre 2009 which is when I think they changed the USB connector into a standard micro usb. Unfortunately mine isn't - you can see the difference here where mine is like the one on the right
I think I'll refit it, make sure the connections are as good as I can make them, and see what happens. Will have the effect of resetting the module as well. If that doesn't work, then I think I may gamble on getting a new module, becuase it's both connections that aren't working properly suggesting module rather than cables (possibly). Is there any other way of a more full/complete reset I can do on the module before doing that?
#20 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
Posted 16 August 2014 - 06:23 PM
arrh yes - I remember that connector now, then again that looks like a standard USB A female connector will a standard USB A male connector fit into it?
#21 mrjudderman
mrjudderman
    Newbie
  • Pip
  • 8 posts
  • Name: Josh
  • Ford Model: Focus
Posted 16 August 2014 - 06:31 PM
it's very slightly smaller. Back in the days when every phone manufacturer had their own connection.
#22 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
Posted 16 August 2014 - 06:42 PM
thats a bit rubbish then.  spose only thing is to find a new module or borrow one if you know someone else with one to prove the fault.  :(
#23 ARRIVAMAN
ARRIVAMAN
    Member
  • PipPip
  • 14 posts
  • Name: ALF
  • Ford Model: FOCUS LX
  • Year: 2007
Posted 18 August 2014 - 03:59 PM
I get some hissing interference when listening to talksport  1089 am and yet all my FM channels are perfect , radio model cd6000 57 plate focus LX , any comments would be appreciated now that the footie season has started . :(
#24 Stoney871
Stoney871
  • Super Mod
  • 18,619 posts
  • Name: Clive
  • Year: 2015
Posted 18 August 2014 - 04:00 PM
Stream internet radio through a phone.
AM/MW was always rubbish.
#25 mrjudderman
mrjudderman
    Newbie
  • Pip
  • 8 posts
  • Name: Josh
  • Ford Model: Focus
Posted 20 August 2014 - 04:03 PM
Ok, so I've decided it's worth getting a new module as it's pretty likely to be the cause of the fault, but is the 8M5T-19C112-AK modules are pretty rare. Is there any problem with fitting a newer module, such as the CS7T-14D212-AC into the 58 Focus. Will there likely be any problems communicating with the radio console? If so, what about just a slightly differnet model, eg the 8M5T-19C112-AP.
The most obvious problem is this:
Is there any adaptor that will take the lead that plugs into the right hand side (which is not a standard usb lead) and plug into the standard micro usb input on the left?
If not, I don't mind splicing them.
#26 troy45
troy45
  • 1,301 posts
  • Name: Troy
  • Ford Model: Focus ST
Posted 20 August 2014 - 04:57 PM
You may have a chance with going from say 8M51 19C112 AK to AP as this is a later engineering level of the AK part.
But really think you'd struggle trying to get the CS71 part to work as this is a completely new part for later models and may not even be classified as the same type of module as what's known as the base number (14D212) is totally different.
Would have to say the odds of that module accepting and working with the software for your car, or working in your car with the software already in it would be slim.
Not what you're looking for?
Also tagged with one or more of these keywords: 6000 CD, aux, bluetooth
