jimbro Posted August 23, 2014 Share Posted August 23, 2014 Just finished the job(sort of) Still have to get a bit of convoluted tubing to put the cables in Power is from 2 x cigarette lighter adapters One takes power from the main socket, the other daisy chains off it. OK since it's all low current devices drawing no more than a couple of amps max. Adapter 1 (2 x std sockets+ 1 x USB in the plug) powers adapter 2 and the HD dashcam Adapter 2 (2 x std socket+2 x USB) powers the iPOD, Sonichi S100 and my phone Cabling to them is tucked under the bottom of the console towards the footwell where I've mounted the power adapters with D/S tape out of the way Originally, I had the DAB antenna on the roof with the cable coming out past the rubber seal on the hatchback but I was getting some wind noise this way. I've now run it into the boot and mounted it under the O/S rear wing upside down(see pic 2) The bracket I used is a Scorpion bracket designed for an 03 Megane(it looked right) and just slips in behind the LH side of the original Sony head unit(didn't even have to remove it) I just drilled a small hole in the Sonichi bracket and fixed it to the Scorpion one with a small screw and nylock nut. So far, the DAB reception seems fine with the antenna in the boot. I'll see how it is when driving around. Cabling will be tidied a bit more when I get the tubing to wrap round the cables and I'll get right angles audio cables so they don't stick out as much from the side of the Sonichi. Cable into the bottom of the iPOD provides power and audio out(splitter). iPOD Audio out goes to AUX IN on Sonichi Sonichi AUX OUT goes to AUX port in glovebox. Just switch the Sony head unit to AUX and everything goes through the Sonichi which also has FM radio. As it goes through the Sony unit, you can also use the steering wheel volume controls. If required, the Sonichi S100 can be removed by unclipping from the plastic bracket and unplugging the cables. Hope this info is of some help. Antenna mounted upside down and stuck magnetically to the wing Quote Link to comment Share on other sites More sharing options...
jimbro Posted August 23, 2014 Author Share Posted August 23, 2014 OK, reception drifts in and out when I'm driving around so the antenna's getting moved back to the roof This time, I'll extend the antenna cable and run it to the back of the boot then route it out and up the side of the tailgate to the rear of the roof. That should eliminate wind noise Quote Link to comment Share on other sites More sharing options...
