hairybiker25412
Brake Light Problem On 2007 Fiesta
I am having a problem with the brake lights on my 2007 Fiesta, The 2 side brake lights aren't working but the midle high level one is working! I have changed both side bulbs but the that hasnt helped, the old ones that came out were fine too, I changed the fuse too but again that hasn't helped and the one that came out was also fine, I then checked the switch behind the brake pedal and it's still working the high level brake light but not the side ones :unsure: Are the standard high level brake lights LED? If so would it have a different fuse? I know LED lights use a lower voltage than normal ones... The car is due MOT in a few weeks so any input would be appreciated :)
Cheers
