LiamVxT Posted September 24, 2014 Share Posted September 24, 2014 Hello, First off apologies if this is in the wrong place. Ihave a 2003 Ford Fiesta, and the passenger side rear door trim cameoff. I bought a new genuine part, and am having trouble fitting it. Here is the new part I have bought: http://i.imgur.com/OhkHcxc.jpg Here is where I am trying to attach it: http://i.imgur.com/8435inK.jpg These white plastic clips are causing me the issue: http://i.imgur.com/EdhPwe1.jpg Ineed to remove them to insert the new ones on the new trim, but Icannot get them out. Look at the new one, they seem to have plasticclips which will grip the inside of the door, to make sure they don'tcome out (easily). Anything I'm doing wrong? Quote Link to comment Share on other sites More sharing options...
Dan62 Posted September 24, 2014 Share Posted September 24, 2014 The clips do pull out. I replaced one of mine a few years back, when another one started to go I used some black silicone rubber to secure it. Quote Link to comment Share on other sites More sharing options...
LiamVxT Posted September 24, 2014 Author Share Posted September 24, 2014 The clips do pull out. I replaced one of mine a few years back, when another one started to go I used some black silicone rubber to secure it. What did you use to get them out? I've tried using pliers and basically the whole car moves before the clips do, and even then they're no closer to coming out. Quote Link to comment Share on other sites More sharing options...
Dan62 Posted September 24, 2014 Share Posted September 24, 2014 I can't remember, probably a couple of screwdrivers to lever them out. Quote Link to comment Share on other sites More sharing options...
julzgeraghty Posted October 1, 2014 Share Posted October 1, 2014 I used a narrow bladed screwdriver to press one side of the clip over, this allows you rotate the clip enough to keep that side out whilst you do the other side. It is fiddly to do though. I used a silicone glue and reused the old trim. Quote Link to comment Share on other sites More sharing options...
William Walker Posted August 4, 2022 Share Posted August 4, 2022 How do is shine the alloy door trims Quote Link to comment Share on other sites More sharing options...
