which bulb?
6 replies to this topic
#1 smcqis
smcqis
  • New Member
  • 57 posts
  • Ford Model: None at present
Posted 30 June 2009 - 03:42 PM
My mk6 1.4 TCDI is due MOT this week and ive just noticed my back left brake light isnt working, which bulb type do i need to get?i assume this bulb is different from the back light that goes on when headlights go on as this worksis it easy to replace ?
Have something to contribute?
#2 smcqis
smcqis
  • New Member
  • 57 posts
Posted 30 June 2009 - 08:41 PM
no one know ?
#3 stepheno
stepheno
    Member
  • New Member
  • PipPip
  • 24 posts
  • Ford Model: fiesta mk6
Posted 30 June 2009 - 09:55 PM
it is the same bulb, its a two filament bulb 21/5w "stop/tail"
replacing the bulb can be tricky but can be done with a phillips screw driver, some time and effort
i can go into detail if your going to do it yourself
#4 smcqis
smcqis
  • New Member
  • 57 posts
Posted 01 July 2009 - 07:43 AM
i would appreciate any help you could give me mate, thanks for the reply need to get me one of those bulbs today, i take it any car shop will have them
#5 smcqis
smcqis
  • New Member
  • 57 posts
Posted 01 July 2009 - 07:54 AM
Is it a single contact or double contact bulb?
#6 stepheno
stepheno
    Member
  • New Member
  • PipPip
  • 24 posts
Posted 01 July 2009 - 05:14 PM
its a double contact bulb
first you need to remove the 2 screws from the outside
then you need to go inside the boot behind the light unit near the bottom there will a electrical plug to disconnect (small button on side)
near this there will be a large cross shaped plastic nut that scews off by hand (might be very tight)
this should release the bottom half of light unit, the top half is held on by a plastic clip which will release with a strong tug
once the unit is off the car the centre section of the rear comes out to access all bulbs
hope this helps, let me know if you have any problems
#7 smcqis
smcqis
  • New Member
  • 57 posts
Posted 02 July 2009 - 11:36 AM
sweet, worked a treat hopefully all is good now, due up in less than an hour
Not what you're looking for?
