tingtongbell Posted June 30, 2009 Share Posted June 30, 2009 Bought a 3-pen Touch Up Kit from Halfords today which comes with only basic instrucitons. Just wondering if any members have had experiences using this kit and like to share some tips! Cheers Quote Link to comment Share on other sites More sharing options...
jasonst170 Posted July 1, 2009 Share Posted July 1, 2009 iv only used 2 pen kits but find. putting pait in the chip and letin it dry. then t cut so there is no new paint ontop of old paint around chip/scratch then top coat it and t cut to blend the new coat to old... Quote Link to comment Share on other sites More sharing options...
slowcraig Posted July 1, 2009 Share Posted July 1, 2009 2 weeks ago i found some small chips on my car, so i went down the local ford dealer, told them my registration number and they were able to get the exact colour for my focus, magna grey, worked a treat once i applied it & used t-cut Quote Link to comment Share on other sites More sharing options...
oto Posted July 13, 2009 Share Posted July 13, 2009 I hardly ever use the built in brush. Use an artist's fine bristle brush instead. Other posters have suggested using t-cut. You can on straight paint but not metallics. Quote Link to comment Share on other sites More sharing options...
jamboken77 Posted July 13, 2009 Share Posted July 13, 2009 I dripped a bit of mine onto the paint below and now it's made that bit look crap, but the scrape looks fine. Anyone know how to clean the dripped part off? Quote Link to comment Share on other sites More sharing options...
oto Posted July 13, 2009 Share Posted July 13, 2009 I dripped a bit of mine onto the paint below and now it's made that bit look crap, but the scrape looks fine. Anyone know how to clean the dripped part off? Assuming you wiped the drip off after it happened, if you can't polish out the remaining blemish with mild cutting compound for clear coat then you may have to use P2000 grit wet & dry then the compound. Be very careful as today's clear coat is not very thick. Halfords has a couple of compounds for clear coat on their shelves. Quote Link to comment Share on other sites More sharing options...
jamboken77 Posted July 14, 2009 Share Posted July 14, 2009 Assuming you wiped the drip off after it happened, if you can't polish out the remaining blemish with mild cutting compound for clear coat then you may have to use P2000 grit wet & dry then the compound. Be very careful as today's clear coat is not very thick. Halfords has a couple of compounds for clear coat on their shelves. Thanks pal, it's not too bad, so probably leave it so not to mess it up even more ;) Quote Link to comment Share on other sites More sharing options...
