supercmaxer Posted October 11, 2014 Share Posted October 11, 2014 Today I fitted the tempeture sensor, with the engine running and looking in the engine bay I noticed that there was air bubbles in the fuel lines so I stupidly decided to turn the air valves on top to release the air but it pushed air in to the lines causing the car to stall. GREAT! I mumbled to myself what did I do that for. I called out the breakdown, now I know what the problem was and all they had to do was take the air out the system with a machine. The guy turns up, undid the inlet manifold pipe sprayed some stuff in whilst I turned it over, it did turn over and fire up but couldn't hold it. The guy then asked for the manual for the car, checked some relays, told me to start it, again it wouldn't fire up. He then came up with probably the fuel pump!!!! WHAT. How did he come up with the diagnose!!! He didn't plug in a code reader for any stored codes, as I thought the fuel pump would have chocked one up. When he put back the hose to the manifold he split the rubber, it wasn't on correctly, the pipe was covered in the spray he used!!!! To say the least was not impressed with his service and diagnose!!!! Got a neighbour to tow me down the road and it fired up first time!!! Now I'm not a mechanic as you are all aware lol. Even my neighbour knew what the problem was and he wasn't impressed either. Rant over. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 12, 2014 Share Posted October 12, 2014 I would complain, tell the recovery firm that he over diagnosed and damaged your car Quote Link to comment Share on other sites More sharing options...
supercmaxer Posted October 12, 2014 Author Share Posted October 12, 2014 I would complain, tell the recovery firm that he over diagnosed and damaged your car When he took of the inlet hose and put it back on he split some of the rubber didn't even put it on correctly, left all spray over the pipe. The recovery company called up and asked if he has arrived. I told them he has been and gone but has told me what he thought the problem was and also that the damage he did to the hose. All she said was oh ok!!! Is the car being taken to a garage. Erm no becuase I fixed it!!! I usually get a questionair about the service so I'll be putting in some choice words that's for sure. Quote Link to comment Share on other sites More sharing options...
stef123 Posted October 12, 2014 Share Posted October 12, 2014 I think the fact that you caused the problem and knew what you had done should have been enough for anyone to day ok it just needs primed properly and it will go.. What a useless numpty of a recovery guy! A little air in the line is normal btw Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 12, 2014 Share Posted October 12, 2014 I would definitely share choice words and I would be looking for a replacement part from them Quote Link to comment Share on other sites More sharing options...
supercmaxer Posted October 12, 2014 Author Share Posted October 12, 2014 I think the fact that you caused the problem and knew what you had done should have been enough for anyone to day ok it just needs primed properly and it will go.. What a useless numpty of a recovery guy! A little air in the line is normal btw That was the point I was trying to make, but for him to remove some relays did have me worried. I usually see air bubbles anyway which as you say is normal, Quote Link to comment Share on other sites More sharing options...
supercmaxer Posted October 12, 2014 Author Share Posted October 12, 2014 I would definitely share choice words and I would be looking for a replacement part from them Just called them up and complained, after explaining to he first guy what had happened he said " do I want it to be revered to a garage" erm no. " I have fixed the problem myself". I told him that the mechanic wrongly diagnosed the problem, and also he has also split the hose and incorrectly put it back on. The guy asked me what is it I want!! Well I want a new hose for one and I am advising you that the mechanic did not fix the problem and if the car was taken to the garage I would of been well out of pocket!!! Will se what happens tomorrow when it's passed on to the correct people. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 12, 2014 Share Posted October 12, 2014 Fingers crossed you get a good result Quote Link to comment Share on other sites More sharing options...
AdeMk1 Posted October 14, 2014 Share Posted October 14, 2014 If it isn't broken don't fix it. :) Quote Link to comment Share on other sites More sharing options...
supercmaxer Posted October 14, 2014 Author Share Posted October 14, 2014 If it isn't broken don't fix it. :) That's what my neighbours say lol Quote Link to comment Share on other sites More sharing options...
AdeMk1 Posted October 15, 2014 Share Posted October 15, 2014 That's what my neighbours say lol :D Quote Link to comment Share on other sites More sharing options...
