focusebony Posted October 14, 2014 Share Posted October 14, 2014 Hi I have engine management light on even while driving have tried to read codes with 2 different obd2 scanners and none of them will connect with the car I have tried the scanners on a different car and they work and read straight away There seems to be an issue with the obd2 port maybe on car ? What can I do to try and fix this Thanks in advance Quote Link to comment Share on other sites More sharing options...
artscot79 Posted October 14, 2014 Share Posted October 14, 2014 Im sure theres a fuse for this ide check the under bonnet and internal fuses Quote Link to comment Share on other sites More sharing options...
troy45 Posted October 14, 2014 Share Posted October 14, 2014 Yup, there's definitely one for the mk2 so I would expect the same for the mk1. If all fuses check out try and get behind the actual socket in the dash in case any of the pins have backed out of the connector, and check the housing is secure in it's bracket. Quote Link to comment Share on other sites More sharing options...
