fusionfan2 Posted October 21, 2014 Share Posted October 21, 2014 When I got my 1.6 petrol Fusion a few weeks back, I asked for a cambelt, tensioners and water pump change as part of the deal, as with 94K on the clock and no record of it being done seemed essential. I have noticed a short intermittent screeching sound, literally blink and you'd miss it. Its generally: - changing up gear (particularly 2nd to 3rd) - when changing gear going up hill - under more heavy acceleration when changing gear (i.e. when I might not be quite as precise and smooth with the clutch) I'm guessing something has been over tightened, but any advice appreciated so I can look informed when I go back and ask for it to be checked. Or will it settle down? (done about 400 miles since the change) Thanks. Quote Link to comment Share on other sites More sharing options...
fusionfan2 Posted October 21, 2014 Author Share Posted October 21, 2014 Actually, from searching, sounds like it could be the clutch then http://www.fordownersclub.com/forums/topic/10315-normal-revs-clutch-screech/ http://www.fordownersclub.com/forums/topic/14084-clutch-squeal/ Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 23, 2014 Share Posted October 23, 2014 Certainly sounds a like clutch issue... Quote Link to comment Share on other sites More sharing options...
fusionfan2 Posted October 23, 2014 Author Share Posted October 23, 2014 Yep, solution looks like precise and smooth gearchanges until it definitely needs a new clutch. Quote Link to comment Share on other sites More sharing options...
