Bluee
One-Touch Electric Windows Problem
If your car is equipped with universal opening then you can control the windows by pressing the lock button on the key once, and then again but this time keeping the button depressed. After a few seconds the windows will close. To open them do the same but with the unlock button. As I said though this only works on certain cars.
Mine does this but since unlocked one press double deadlock it wont do it pressing keyless button on handle but will work on remote fob.
Yunii
I have tried this but to no avail.
From the driver side switch: the driver side window works correctly but the passenger window does not auto one touch open nor close.
I do not have any wind deflectors installed so I'm wondering if the passenger windows even have one touch activated or installed?
Anyone else experience this?
My drivers side window works fine, however passenger side doesn't. I tried the suggestion mentioned here last night and after ten seconds, there is a click and the window stays up. It then won't go back down until I hold the button down for ten seconds, at which point it stays down and won't come back up unless I hold again for ten seconds, and so on!
Has anyone else had this issue? The passenger window is significantly slower than drivers, if that makes any difference.
After fitting my wind deflectors my passenger side window wouldn't open/close on the global function. Re-programmed it by fully lowering it then closing it and held the button up for 10 seconds, which cured it so global option now functional again.
Good to know guys as mine went back to the dealer with this fault, took an age to get booked in as I had to speak to central booking line who were not overly happy I wanted to wait with my Car as they said it could be a big job.
Waited a week for my appointment at the dealer and it was done in no time, so I had a coffee while the valeted it for me
I have a 2012 zetec s my drivers window has one touch open and close but passenger doesnt i think its just the way ford made them it did it without the wind deflectors i fitted to my car.
Guys and Girls, slightly different problem I think, apologies if I'm being a bit thick, Had my Zetec 3dr for a few days its a 2014, both windows will only open to half way? did have the battery disconnected to do a sub install, do you think this is just a reset issue?
My drivers window drops in 5 steps but the passenger drops in one go (as long as I keep holding the button, not one touch) I tried holding the buttons for 10 seconds but it didn't work, any one had this?
Mint! Works for me after battery fully dead..... Thanks BP2411 for the link to this sticky which I never saw :blush:
I picked my car up today and mine does exactly as you've described as well with the slow Windows and clicks.
Only the drivers window works with 1 click the rest do as you mentioned.
Did you manage to sort it out?
Thanks for the help both windows working now .Ford are useless ,i phoned them and they said they may have to get new parts .Service department should know about this little trick . They don,t even reset the clock after they disconnect the battery .Why did i ever buy a Ford .
I'm afraid not, haven't been able to find a fix as yet.
Thanks for the reply.
I found out the its only the drivers side that is one touch and as for the slow windows spraying the rubber channels with silicone spray has helped them tremendously.
They all now go up at the same speed, so i'd do that if your still having a problem :smile:
Appreciate it's a bit of a resurrection and a bit off-topic but probably worth noting in case it solves your issue or helps someone else.
When i got my car a week ago, the passenger window was going down half way. It worked fine going up and down but always stopped at the same spot.
Upon removing the door card, i realised it was blocked by the mirror cable. It appears the previous owner had replaced the mirror and didn't feed the wire correctly so it was crossing the path of the window as it went down.
Initially i tried removing the inner door card also, but it wasn't necessary.
An easy way to feed it correctly, is to remove the mirror completely, lower the window fully and then feed the mirror cable. This way, the wrong path will be blocked.
My recent experience with this is, I have 1 touch up and down but had to set the one touch up on my passengers side and then holding the lock and unlock button on the fob makes the windows open and close
Help, one touch is not working on my drivers side
Passenger's side works fine but drivers side only goes down with one touch it wont go up, any ideas?
Tried the reset options in this thread and in a manual I have but no joy...
