marcus99 Posted November 6, 2014 Share Posted November 6, 2014 I have recently changed 2 heat resistors. 1st one didn't work at all 2nd one worked perfectly for few weeks. Now I have not a lot. It doesn't blow out any heat at all in the car or on the windows. Only time can get it to work is with the window down half way but then the heat is like half a no 1. Can also hace heaters switched on cold and 0 and still get this petty amount of hest.Also front heated screen doesn't work. Is this linked any way at all Any help or ideas please as don't want to take to garage to get ripped off Quote Link to comment Share on other sites More sharing options...
marcus99 Posted November 6, 2014 Author Share Posted November 6, 2014 ... Quote Link to comment Share on other sites More sharing options...
mick85 Posted November 8, 2014 Share Posted November 8, 2014 Is blower motor workin Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
marcus99 Posted November 9, 2014 Author Share Posted November 9, 2014 Is that the part just above where the heater resistor is ? If so what would I do to check this ? Quote Link to comment Share on other sites More sharing options...
marcus99 Posted November 11, 2014 Author Share Posted November 11, 2014 I have been to a garage today he tested few bits and bobs and says the blower motor has gone. It keeps blowing a new fuse every time a new one is put in Is it just a case of getting old blower out and new blower in and clipping it back in and I'll have heat or any other bits that need doing like cable or testing it or anything ??? Quote Link to comment Share on other sites More sharing options...
marcus99 Posted November 11, 2014 Author Share Posted November 11, 2014 ..... Quote Link to comment Share on other sites More sharing options...
marcus99 Posted November 12, 2014 Author Share Posted November 12, 2014 I have changed the blower motor pretty simple job. The heat resistor is still fine checked that also put new cabin filter in. Only issue is still no heat. Have I missed anything or what else could it be ? Quote Link to comment Share on other sites More sharing options...
mick85 Posted November 13, 2014 Share Posted November 13, 2014 So are u gettin power to blower motor Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
marcus99 Posted November 13, 2014 Author Share Posted November 13, 2014 Nope no power to the blower. The fuses are ok but the other day bloke at garage said kept blowing the fuses Quote Link to comment Share on other sites More sharing options...
mick85 Posted November 13, 2014 Share Posted November 13, 2014 So no voltage at pin one at blower motor green an orange an fuse 64 is ok Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
marcus99 Posted November 16, 2014 Author Share Posted November 16, 2014 How would I test that. Would that be garage trip for them to test it. And yeah fuse is fine Quote Link to comment Share on other sites More sharing options...
mick85 Posted November 16, 2014 Share Posted November 16, 2014 U need multimeter or a circuit tester u can buy either for cheap enough Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
marcus99 Posted November 16, 2014 Author Share Posted November 16, 2014 Don't think I'll need 1 for myself. Surely garage would do it. Is the chances it not working down to a cable being wet. forgot to mention had coolant leak the other week in passenger footwell. Quote Link to comment Share on other sites More sharing options...
mick85 Posted November 16, 2014 Share Posted November 16, 2014 Coolant leak inside car that's heater matrix leaking Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
marcus99 Posted November 17, 2014 Author Share Posted November 17, 2014 So I'm pretty much screwed with it them been told that's a dashboard out job. Quote Link to comment Share on other sites More sharing options...
