Esp Light Staying On
willc
 Share
My ESP light csme on the other day and i cant switch it off!! Tried tick or unticking it from my control menu but not having much luck.
Anyone experience this issue? Is my ESP unit knackered??
Will
Link to comment
Oh and i have a fault code reader, it came back fsult code C1288- chassis... ?
Link to comment
DTC C1288 is related to the pressure sensor of the ABS / ESP pump. This is a known problem of the ABS / ESP pumps that are used in the Focus MK2 / MK2.5 (and many other vehicles). The solution for this problem is replacing the hydraulic part of the pump. On some ABS/ESP pumps it is only possible to reclame the complete pump.
There are also specialized companies which can repair/rebuild the defective pump. They will replace the weak parts which are known causing this problem for uprated parts.
Link to comment
As I understand it Ford used to only supply the complete ABS modulator, for a rather hefty price.
But now they do sell the components needed to repair your existing unit when the pressure sensor has gone belly up.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
