crazylady Posted November 10, 2014 Share Posted November 10, 2014 I have a C max titanium 2011 , when we have rain water accumulates on the ledge at the bottom of the drivers door , consequently when you open the door you get wet feet , At first the garage said it was because I was parking on a hill ( does that mean they should warn you not to but this model if you live on a hill ) The garage then tried to fix this by adjusting the door , no luck just meant the door was catching and out of alignment . Then trying again put the door bak and drilled holes in the bottom of the rubber seal ?? still gathering water , Any ideas Quote Link to comment Share on other sites More sharing options...
MattDRX Posted November 10, 2014 Share Posted November 10, 2014 Its not the rubber, at the bottom of the door there are some very small holes, common on Frauds to block up, just give it a stab with a small pick or something and watch the waterfall that follows. Quote Link to comment Share on other sites More sharing options...
crazylady Posted November 10, 2014 Author Share Posted November 10, 2014 They did that on the first visit but no good someone has mentioned A-post joint Quote Link to comment Share on other sites More sharing options...
