Adam F Posted November 13, 2014 Share Posted November 13, 2014 Hi all, I have a water leak, offside in the boot. Appears to drip down from the slatted vent in the corner and from behind the auxiliary power outlet. Anyone had this issue or know how to stop it? I'm not keen on the damp smell it's creating! Cheers, Adam Quote Link to comment Share on other sites More sharing options...
troy45 Posted November 13, 2014 Share Posted November 13, 2014 Some Focus hatchbacks had problems where the tailgate hinge pockets needed re-sealing, not certain if the estate could also suffer from this. Another possible area would be the rear light fittings and wiring grommets. Sometime it's worth just diving in to strip the side trim out, dry up all the water that's there then use a hosepipe or small jug to put water onto the back end of the car and start tracing where you can see it coming into the cabin. Quote Link to comment Share on other sites More sharing options...
andy_gib Posted November 14, 2014 Share Posted November 14, 2014 Had the same problem. Turned out to be small gaps/holes letting in water at the end if the roof rail. Water running down into vents/Believe it's a well documented problem with the Mk2 estate. Stupidly took it to the local ford dealer who charged a small fortune to fix. Initially they just put a little bit of silicon around the joins but leak still persisted. Later took off roof rail & inside trim, sealed from inside & out. Would probs give it ago myself next time if the other side goes. Also check boot hinges & rear light fittings. Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Adam F Posted November 14, 2014 Author Share Posted November 14, 2014 Thank you both for the comments. I think I'll start with the easy ones, hinges and light fittings. Hopefully that will resolve it. I have to admit I have looked at the roof rails and thought "what if..." Quote Link to comment Share on other sites More sharing options...
