jace1969 Posted November 15, 2014 Share Posted November 15, 2014 As the title,most times its a blue screen then it goes off,beeps still work all the time. Camera is clean and not wet,its the rear-view-mirror one. Where are these connected to like on the gearbox or is it just connected to the reverse lights Do you get at the camera behind the boot panel inside as no screws outside. to trigger it to work,just seeing anything to do or check as was on car when other person had car new. I have had car 2 weeks and covered under warranty. Thanks Quote Link to comment Share on other sites More sharing options...
jace1969 Posted November 15, 2014 Author Share Posted November 15, 2014 Glad it was on the car when i had it because don't think i would pay for one. So i did think that not a lot would have these or know a lot about them. So next thing then,how do you take the inside panel of the boot off as can't see any screws so i can look at the wires. Quote Link to comment Share on other sites More sharing options...
jace1969 Posted November 16, 2014 Author Share Posted November 16, 2014 Removing inner boot plastic,just pull it or some hidden screws that i have missed. Quote Link to comment Share on other sites More sharing options...
Willy Posted November 16, 2014 Share Posted November 16, 2014 One screw where you grab the boot lid the and a screw each side of the windows trim then pull away Quote Link to comment Share on other sites More sharing options...
jace1969 Posted November 16, 2014 Author Share Posted November 16, 2014 One screw where you grab the boot lid the and a screw each side of the windows trim then pull away Thanks a lot,will have a look see if something is loose. Quote Link to comment Share on other sites More sharing options...
jace1969 Posted November 17, 2014 Author Share Posted November 17, 2014 Not much luck with this,all i want to do is check the wires are ok and not wet/damp. Taken the back of tail gate off and can't get at it,can't even see any wires in that direction. How do you get to the wires as its not part of the number plate light,taken the light off and still no joy,does the trim pull off whetre the lights fit into. Quote Link to comment Share on other sites More sharing options...
jace1969 Posted November 18, 2014 Author Share Posted November 18, 2014 Easy way round this,turn it off. Quote Link to comment Share on other sites More sharing options...
Willy Posted November 18, 2014 Share Posted November 18, 2014 There's 6 / 8 10 mm nuts to remove to get to the wiring. You may also need to remove the wiper motor to gain access to the other nuts. Quote Link to comment Share on other sites More sharing options...
jace1969 Posted November 18, 2014 Author Share Posted November 18, 2014 There's 6 / 8 10 mm nuts to remove to get to the wiring. You may also need to remove the wiper motor to gain access to the other nuts. So the wiper and the plate behind the wiper needs to come off,mmmmmmmmmm think i will leave that. It seems that its damp as works better after i have been in the car about 30mins. Quote Link to comment Share on other sites More sharing options...
jace1969 Posted January 15, 2015 Author Share Posted January 15, 2015 Just had car back from going into ford for new reverse camera,works fine for now. All done under my AA cover so got my money back from my cover i paid for. It is the same color coded plastic cover just a new lense and stuff inside,sure these aint a lot to buy,i had brake fluid changed and new camera and £326 all in under cover. Are these on eBay to buy. Quote Link to comment Share on other sites More sharing options...
