cpjvej2014 Posted November 17, 2014 Share Posted November 17, 2014 Focus Mark 1 I believe on a 51 Plate, Central Locking stops completely when it rains, when driving along and the car has warmed up a bit the locks start working as im driving along. I can only put this down to Moisture getting into the door and getting into the Mechanism and into the Modules in the door ? Is this a common problem ? Any fixes ? Once things have warmed up and the car has been used for a while it seems to start working again! Any Ideas ? Thanks in Advance Chris. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 27, 2014 Share Posted November 27, 2014 is it all doors that are affected, or just the one? Quote Link to comment Share on other sites More sharing options...
cpjvej2014 Posted December 2, 2014 Author Share Posted December 2, 2014 All doors, if I go outside now it won't work. But after driving a while the locks make a noise whilst im driving and then they work again! Most annoying trying to get little kids in the car! Any Ideas ? Quote Link to comment Share on other sites More sharing options...
STEADS Posted December 2, 2014 Share Posted December 2, 2014 First point of call I would look at the master lock on the drivers door see if you can see anything untoward on the electrical connection your correct I would say in thinking moisture is affecting it possible over time the contacts have come corroded and are shorting out .have a look and get back to us Quote Link to comment Share on other sites More sharing options...
cpjvej2014 Posted December 2, 2014 Author Share Posted December 2, 2014 Thanks Steads! I'll check at the weekend. Ill rip door card off and see if I can spot anything. Thanks Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 2, 2014 Share Posted December 2, 2014 Quite common problem on mk1 and facelift models. It is indeed water getting to the central locking module. I had it on my mk1 and had to resort to carrying a spare key in case the car relocked itself while warming it up in the winter before leaving work. Quote Link to comment Share on other sites More sharing options...
