scottmc1991 Posted November 23, 2014 Share Posted November 23, 2014 i have a just got my mk7 fiesta and im thinking about getting a dash cam as the car park were i work is ridiculous cars are always getting keyed or banged. So i was wondering if any one on here has one and are they any good. Quote Link to comment Share on other sites More sharing options...
MarksST Posted November 23, 2014 Share Posted November 23, 2014 I have a blackvue 650, not cheap but includes a rear view camera and has gps wifi. It has a park mode that if the car is knocked it the camera starts recording. There are loads of different cams on eBay from £20-30, most will be up to the job. Quote Link to comment Share on other sites More sharing options...
scottmc1991 Posted November 23, 2014 Author Share Posted November 23, 2014 thanks mate i will have a look. Quote Link to comment Share on other sites More sharing options...
Gary.J Posted November 23, 2014 Share Posted November 23, 2014 Unless you have a camera on all 4 sides of the car, you'll not pick up sideswipes or keyings. Plus as mentioned, you need a cam that operates when your car is parked. Someone maliciously scratching the car isn't likely to start it recording, anyway. Quote Link to comment Share on other sites More sharing options...
MarksST Posted November 23, 2014 Share Posted November 23, 2014 If you get a big enough memory card you can leave it to record all the time. You can adjust the sensitivity of the camera too. Connect the power supply using a power magic unit which turns the camera power off at a set point to save the car battery. Quote Link to comment Share on other sites More sharing options...
Stevek1909 Posted November 23, 2014 Share Posted November 23, 2014 Funny you should ask this question I spent ages looking around finally went for DRIVE-EYE 1080p, GPS,135 Degree ultra wide angle lens,2 Mega Pixels, G-Sensor, Seamless Loop.....and its so easy to fit I bought the hard-wire kit but messed up it came with a standard size blade fuse but the Fiesta ST has Mini Blade Fuses ordered one off eBay for £2.00 altogether it came to £91.99 seams to be great at the moment does what it says on the box oh I also had to buy a Micro SD card got the largest one it could take 32GB..when I get chance will get some screen shots up. Quote Link to comment Share on other sites More sharing options...
Stevek1909 Posted November 30, 2014 Share Posted November 30, 2014 Here you go some images off the dash cam... :D you also get a GPS read out with Google maps but its not shown in the screen shots. Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted December 1, 2014 Share Posted December 1, 2014 If you're looking for something cheap the Mobius is the way to go at around £40. It can match a lot of more expensive cameras in video quality and has a motion sensing mode so I guess that could be used when parked. Quote Link to comment Share on other sites More sharing options...
