Is there anyway of adjusting the doors.
My nearside passenger door has suddenly started to
scrape on the front nearside wing.
mkj
Door Problem
Started by mkj, Jul 09 2009 04:51 PM
2 replies to this topic
#1
Posted 09 July 2009 - 04:51 PM
#2
Posted 09 July 2009 - 07:31 PM
if there is any adjustment it will be done by slackening the bolts on the hinges, are the hinge pins ok? if the door is opening wider that before it could be the stop bar in the door jar broken.
#3
Posted 09 July 2009 - 10:31 PM
Thanks for your reply, by the look of things the Hinge Pins look fine.
It seems the bottom of the door has moved slightly and is rubbing on the front panel causing the paint to chip.
