johnpaul54 Posted November 24, 2014 Share Posted November 24, 2014 Hi I am new on here so I hope I am on the correct bit of the fourm. I have purchased a 52 reg mondeo tdci with two keys the manual type, I dident get a remote one ,what is the cheapest way to get a key to work (remote type) and advice would be great ,the two keys I have have the little blue bit on them , regards johnpaul Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 24, 2014 Share Posted November 24, 2014 You need to make sure you actually have remote control feature on it. What Model is it? LX, Zetec, Ghia? Check behind the map light and see if there is a box. Quote Link to comment Share on other sites More sharing options...
johnpaul54 Posted November 24, 2014 Author Share Posted November 24, 2014 hi thanks for you reply it is a tdci lx 2.0 .apparently it came with a remote fob but was lost at some stage , Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 25, 2014 Share Posted November 25, 2014 Check that you still have the receiver but if that's the case it's easy to fix. Search eBay for Ford key chain remote. You can buy not of these and they would work. I have seen people use the likes of the 14 quid ones and they work well. If it's the same for yours as mine, you then need to stick the key in, twist from 2 to 0 repeatedly till the cars in learning mode, then just press any button on the remote. Car should acknowledge this and that remote should now work. Alternatively you can replace your key with a proper Ford branded one, but if you don't want to spend that much it should be achievable with the aftermarket Quote Link to comment Share on other sites More sharing options...
