NL06NKA Posted December 7, 2014 Share Posted December 7, 2014 Hello All, My Gear Stick Has Just Stopped Working. I Think I Might Need A New Selector Or My Old One Fixed, Does Anyone Have A Rough Idea Of Prices To help Me Out ? Thanks People Quote Link to comment Share on other sites More sharing options...
JW1982 Posted December 7, 2014 Share Posted December 7, 2014 You should first remove the gear selector boot cover. Below the cover is the gear selector mechanism with the 2 shifter cables attached to it. If one of these cables came off the gear selector does not work. If this looks OK you can remove the plastic cover on the gearbox. If the cover is removed you can see the 2 shifter cables connected to the shifter mechanism on the gearbox. At this point the shifter cables can also came off the shifting mechanism. Many times shifting problems are caused by a shifter cable which came off the mechanism or an incorrect adjusted mechanism caused by a broken adjuster at the end of the shifer cables. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 7, 2014 Share Posted December 7, 2014 If you find you need a replacement shifter mechaniam I have a spare 5 gear mech out of an 09 1.6 Focus including the cables. I'd only be looking for postage (largish box), say £20. Quote Link to comment Share on other sites More sharing options...
Phil121 Posted November 4, 2019 Share Posted November 4, 2019 Hello I have a 07 plate focus won't go in 5th gear all other gears are fine doesn't even feel like it's trying to go in gear no crunching just comes to dead stop on gearstick in the car could it be a problem gearbox end with the selector anybody had this problem before ? Quote Link to comment Share on other sites More sharing options...
Adrian Dawson Posted September 23, 2021 Share Posted September 23, 2021 Why does my st mk2 feel like it needs another gear only had it 4 weeks Quote Link to comment Share on other sites More sharing options...
giannhst13 Posted December 7, 2023 Share Posted December 7, 2023 Ford focus 1.5 ecoboost 182 st-line x 2020 automatic Hi, I Have the same problem. The message “gear selected will engage at low speed” appeared on my car’s screen, when I changed D to R and at the same time there was a strong vibration-shock in the car gearbox. I sent the car in a specialised garage since it has a guarantee. Three months later since they checked the car, upgraded it and restarted it, they gave it back to me, ready to use. Unfortunately when I drove it for about 300 kilometres, the problem showed up again. My car delivered to the garage again, they checked it and I was stand by, until the factory gave the order to change the car’s gearbox unit .I have already done 200 kilometres with the new gearbox and now the message showed up again in the transition from D to R. . The message turns off immediately after 2 seconds.This problem appears every time I switch from D to R! After the change gearbox the vibration-shock is a little bit softer. What’s the solution? I have read that other customers have also problems like this. Quote Link to comment Share on other sites More sharing options...
