motley Posted July 12, 2009 Share Posted July 12, 2009 My daughter has a "W" (2000) Fiesta Zetec 16 valve and when she was driving she had set the heater to blow cold air, aftera bit the heater started to blow hot air and I have had a look at the control switch on the dash and cannot see if anything is wrong. Has anyone any suggetions as what to look for and a possible cure please Many Thanks Motley :) Quote Link to comment Share on other sites More sharing options...
fiesta_lad Posted July 13, 2009 Share Posted July 13, 2009 My daughter has a "W" (2000) Fiesta Zetec 16 valve and when she was driving she had set the heater to blow cold air, aftera bit the heater started to blow hot air and I have had a look at the control switch on the dash and cannot see if anything is wrong. Has anyone any suggetions as what to look for and a possible cure please Many Thanks Motley :) Check the coolant level it may be low. you may have a slow leak. there is a number of things you may check the heater valve and your thermastat let me know the outcome Quote Link to comment Share on other sites More sharing options...
mintalkin Posted July 13, 2009 Share Posted July 13, 2009 the heater controlle valve is a known bad spot. Quote Link to comment Share on other sites More sharing options...
motley Posted July 14, 2009 Author Share Posted July 14, 2009 the heater controlle valve is a known bad spot. Possibly sounds thick of me but where do I find the heater control valve ? and dont say "Under the bonnet" :D :D Any pictures of its exact location or a good description of location please, then I know exactly what I`m looking for Many Thanks Motley Quote Link to comment Share on other sites More sharing options...
