mattchrome Posted December 15, 2014 Share Posted December 15, 2014 My instrument cluster has developed a strange intermittant fault. The orange lcd display fades to a ghost, the gauge illumination goes totally off. and the indicators become silent. All of these things work one minute and stop another. It might happen twice in a minute or perhaps only once in an hour. there are no clues as to what causes this as no amount of bumps will cause this to happen, and no amount of switching lights etc also does not cause it. heat in the cabin also does not seem to affect it either. Has anyone had a similar problem? I thought of removing cluster and cleaning circuit board and multiplug and cleaning with switch cleaner, but am wary of causing more damage. Anyone? or in the absence of replies, suggest a reputable auto electrician? Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted December 17, 2014 Share Posted December 17, 2014 So to clarifity the cluster loses all backlight illumination only sometimes not always? Does anything else lose power or lighting? Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted December 17, 2014 Share Posted December 17, 2014 have you checked the plug to makes sure it is pluged in properly ? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 17, 2014 Share Posted December 17, 2014 http://www.clusterrepairsuk.co.uk/repair/make/ford?utm_source=google&utm_medium=cpc&utm_term=ford%20focus%20dash%20repair&utm_content=Ford&utm_campaign=CRManufacturerKeywords Quote Link to comment Share on other sites More sharing options...
mattchrome Posted December 17, 2014 Author Share Posted December 17, 2014 Hi, in answer to nazsky786, no, only the things I mentioned, everything else is fine including the lighting outside the car. Oh,1 other thing, the sound ot the seat belt warning bong sometimes becomes silent. And to mrmetallica No,I haven`t removed the cluster yet to check multiplug, do you think I should? And thanks to Stoney871 for the info! Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted December 17, 2014 Share Posted December 17, 2014 Hi, in answer to nazsky786, no, only the things I mentioned, everything else is fine including the lighting outside the car. Oh,1 other thing, the sound ot the seat belt warning bong sometimes becomes silent. And to mrmetallica No,I haven`t removed the cluster yet to check multiplug, do you think I should? And thanks to Stoney871 for the info! it wouldnt hurt.you never know Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted December 17, 2014 Share Posted December 17, 2014 You might have the common cluster issue. Quote Link to comment Share on other sites More sharing options...
mattchrome Posted December 17, 2014 Author Share Posted December 17, 2014 To nazsky786 What is the common cluster issue, and how do I fix it? Cheers! Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted December 17, 2014 Share Posted December 17, 2014 People have tried resoldering the connected point on the cluster main board, this has the highest success rate. Some used wd-40 on the board. And some used pcb cleaner. Or give it to a professional to check. Around £40 repair cost. If all else fails you can get one from another car and program it to your car. Cost is around £250-300 as the tools to program are expensive Ford don't normally do it. Quote Link to comment Share on other sites More sharing options...
