clakyp Posted January 7, 2015 Share Posted January 7, 2015 Anybody else have a problem with their bakes fiesta S1600 2010 the pedal goes really far down to the floor but does stop the car has been into a dealer & had a computerised bleed did improve slightly but few months later back to the same dealer said its one of those things common on these & zetec s anybody on here had the problem & got it sorted Cheers Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Paramanic Posted January 7, 2015 Share Posted January 7, 2015 how is your brake pads? because is it goes right down could be your brake pads are wearing down or fluid but as you said fluid is fine a suggest checking the pads but apart from that ....my knowledge only goes so far :P Quote Link to comment Share on other sites More sharing options...
Mike77 Posted January 7, 2015 Share Posted January 7, 2015 Had this on mine on the test drive, garage said they would sort it before I picked it up. Few days later after their mechanics were left scratching their heads it ended up in fords. Turned out to be the ABS unit, apparently its quite a common problem ? But it cost the garage nearly £300 to put right... but did solve the problem. Quote Link to comment Share on other sites More sharing options...
clakyp Posted January 7, 2015 Author Share Posted January 7, 2015 Cheers ... Deffo not pads heard a few people have had the problem but never a solution .. Wonder if it's worth getting another ABS unit & re bleed the system them Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
B13 Posted January 8, 2015 Share Posted January 8, 2015 Yep! Despite my protestations that Mk 7 brakes are renowned for being 'soggy', my mechanic fella insisted that I should consider having my pads and discs replaced. The look of embarrassment on his face after he'd done it and realised that the brakes were STILL soggy was priceless!! :D Sent from Ye Olde iPadde using Ford OC Quote Link to comment Share on other sites More sharing options...
Paramanic Posted January 8, 2015 Share Posted January 8, 2015 Only said pads because the mk6 I had had this and was because of the pads lol Quote Link to comment Share on other sites More sharing options...
MattDRX Posted January 8, 2015 Share Posted January 8, 2015 Soggy brakes is air in the system, just give them a bleed and top up after, will sort it and make the pedal nice and firm. Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted January 8, 2015 Share Posted January 8, 2015 Is there any documentation showing the brake fluid has been changed in 2-3 years? Brake fluid absorbs moisture from the air and water can be compressed more than brake fluid can. Air of course is far worse, but with water in the brake system, that can turn to steam when the brakes are used heavily meaning no brakes.... Just when you need them most.... Sent from my iPad using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Mike77 Posted January 8, 2015 Share Posted January 8, 2015 Soggy brakes is air in the system, just give them a bleed and top up after, will sort it and make the pedal nice and firm. This is not always the cure. It would obviously be the first port of call. But in my case, the system was bled, problem still there, then it was pressure bled at a garage, still the same. Then ford diagnosed the ABS control module, replaced it, pressure bled it again and its been fine ever since.... Quote Link to comment Share on other sites More sharing options...
Paramanic Posted January 8, 2015 Share Posted January 8, 2015 Anybody else have a problem with their bakes fiesta S1600 2010 the pedal goes really far down to the floor but does stop the car has been into a dealer & had a computerised bleed did improve slightly but few months later back to the same dealer said its one of those things common on these & zetec s anybody on here had the problem & got it sorted Cheers Sent from my iPhone using Ford OC lol a read this not the spongy part lol Quote Link to comment Share on other sites More sharing options...
clakyp Posted January 8, 2015 Author Share Posted January 8, 2015 Yes fluid has been changed had a digital bleed with fluid changed slightly better but not how they should be ... Maybe look at the ABS then & see if that works Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
iantt Posted January 8, 2015 Share Posted January 8, 2015 Known issues with a few abs units, rarely needs abs unit, usually need bleeding via abs pump on diagnostics. 1 Quote Link to comment Share on other sites More sharing options...
clakyp Posted January 8, 2015 Author Share Posted January 8, 2015 Who can bleed them via the ABS pump Ian ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
iantt Posted January 8, 2015 Share Posted January 8, 2015 Only ford dealers using ids dianostics normaly, unless anyone else knows different, sure theres a software update on abs module aswell. Quote Link to comment Share on other sites More sharing options...
clakyp Posted January 8, 2015 Author Share Posted January 8, 2015 Ok might give the local dealer a bell see if they think they can do it .. Cheers Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
iantt Posted January 8, 2015 Share Posted January 8, 2015 Ask them to use symptom based diagnostics for brake pedal travel. Quote Link to comment Share on other sites More sharing options...
clakyp Posted January 8, 2015 Author Share Posted January 8, 2015 Will do cheers Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
