blackbacks Posted January 17, 2015 Share Posted January 17, 2015 Hi all Driving in the snow and ice over the past couple of weeks I noticed when I brake hard I get a grinding/metallic sound from brakes. Noise is not there in normal conditions- brakes are fine. Car is 1.6 zetec petrol with abs and esp (I think) Any thoughts? Quote Link to comment Share on other sites More sharing options...
STEADS Posted January 17, 2015 Share Posted January 17, 2015 Possible grit or is it first thing after a wet night as mine grind a bit on first braking after it's been wet the previous evening just like a light surface rust gets on them after that first initial brake there fine . Quote Link to comment Share on other sites More sharing options...
blackbacks Posted January 17, 2015 Author Share Posted January 17, 2015 Cheers for the reply Steady First things I checked- but no everything's fine. Have a feeling it's to do with the Esp system but as I've not had a car with Esp before can't be sure Quote Link to comment Share on other sites More sharing options...
IINexusII Posted January 17, 2015 Share Posted January 17, 2015 thats how the abs works i think, makes that sound. youll also feel that the brake pedal doesnt go all the way, it sort of restricts your pressure 1 Quote Link to comment Share on other sites More sharing options...
troy45 Posted January 17, 2015 Share Posted January 17, 2015 As above, it'll be the ABS kicking in - if you're able to get on a big wide open road/supermarket car park/field which is snowy, and clear of traffic etc just try braking as hard as possible at low speed to trigger the ABS and compare it to when you brake gently enough not to cause the wheels to lock-up. 1 Quote Link to comment Share on other sites More sharing options...
