gazza81288 Posted January 18, 2015 Share Posted January 18, 2015 Hi all I have had my st since October and it seems to have developed a problem with the iphone/USB connection. I never had this problem at all with my other st and this is the third time this has happened now. It looks like this http://s29.postimg.org/tgir70hav/image.jpg anyone have any ideas on how to sort this out? Thanks Quote Link to comment Share on other sites More sharing options...
StevenST13 Posted January 18, 2015 Share Posted January 18, 2015 Not had that problem but have been having problems with mine. My ST's iPod connection has a mind of its own at times mostly it's fine then it'll just disconnect and I have to mess with it to get it to recognise it again. But when it is mostly working the info on the screen is perfect. Not come across that issue your having. Quote Link to comment Share on other sites More sharing options...
avatarmamo Posted January 18, 2015 Share Posted January 18, 2015 And did you try to use a different usb ? If need be download the software from ford and reinstall it via usb. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
gazza81288 Posted January 18, 2015 Author Share Posted January 18, 2015 Yeah mine is usually fine but it seems to have developed this fault. Sometimes turning iPhone off and on does solve it then when the car is turned off it goes back to the above picture and won't play ball. I have tried my hdd and usb and they work fine. I don't want to take it back to ford as heard they have screwed people's steroes up with a software update even though mine is still under warranty Quote Link to comment Share on other sites More sharing options...
gazza81288 Posted January 23, 2015 Author Share Posted January 23, 2015 Still having problems with the above issue, would disconnecting the battery have an effect as it resets all electrical modules? Quote Link to comment Share on other sites More sharing options...
MattDRX Posted January 23, 2015 Share Posted January 23, 2015 Avatar whatever, how do you download the software and install it via USB? it's not going in the UK? Quote Link to comment Share on other sites More sharing options...
avatarmamo Posted January 23, 2015 Share Posted January 23, 2015 Download it from the ford website and put it into the usb. Then connect the usb to the car and follow the wizard Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
