REMOTE KEY
6 replies to this topic
#1 RUSSBUS
RUSSBUS
    Member
  • PipPip
  • 25 posts
  • Ford Model: C MAX 1.6 ZETEC
Posted 24 April 2008 - 09:15 AM
DOES ANYBODY KNOW IF IT IS POSSIBLE TO PROGRAME A REMOTE TO START A C MAX ON A DIY BASIS I KNOW I CAN PROGRAME ONE TO OPEN THE CAR BUT HAVE HEARD ONLY FORD CAN PROGRAME TO START . ALSO I HAVE SEEN JAGUAR FOBS ON THE NET THEY WORK ON FOCUS C MAX AND MONDEO BUT THE SELLER DID NOT KNOW IF THEY WORK ON A NEW SHAPE C MAX , ANYBODY ANY IDEAS PLEASE ?
THANKS RUSS
P.S . IF I TRY TO PROGRAME A REMOTE AS PER HANDBOOKINSTRUCTIONS IS THERE ANY DANGER OF THE ORIGINAL REMOTE NOT WORKING AFTER OR DOES IT NOT AFFECT EXISTING ONES ?
#2 RUSSBUS
RUSSBUS
    Member
  • PipPip
  • 25 posts
Posted 25 April 2008 - 09:08 AM
THANKS RUSS
#3 Steve
Steve
    Administrator
  • Admin
  • 4,824 posts
  • Ford Model: Kugy
Posted 25 April 2008 - 06:36 PM
only ford can do this as they link up to the ecu i would imagine.
However, this is a 10 min job so dont let them charge the earth. Get a quote first
#4 RUSSBUS
RUSSBUS
    Member
  • PipPip
  • 25 posts
Posted 25 April 2008 - 09:17 PM
BEEN QUOTED £90 AT LOCAL FORD DEALER
#5 RUSSBUS
RUSSBUS
    Member
  • PipPip
  • 25 posts
Posted 26 April 2008 - 07:15 PM
BORROWED A REMOTE FROM A FRIEND WHO HAS A MK3 MONDEO AND IT PROGRAMED TO OPEN MY CAR SO HAVE COMPARED REMOTES ON E BAY AND JUST BOUGHT ONE FOR £42 NEW , I THINK IT SHOULD WORK TO OPEN AND UNALARM MINE . FINGERS CROSSED I WILL LET YOU KNOW THE OUT COME .
#6 Steve
Steve
    Administrator
  • Admin
  • 4,824 posts
  • Ford Model: Kugy
Posted 28 April 2008 - 05:50 PM
£90 i guess is for 1 hours worth of work.. do they charge 90 an hour at your dealership?
#7 ianwood
ianwood
    Newbie
  • Pip
  • 3 posts
  • Ford Model: mondeo
Posted 02 June 2008 - 05:02 PM
Hi
in the head there are two things 1st there is the remote that operates the doors (deadlocks & sets alarm) which the car can program by the handbook. Secondly there is the transponder which is activated as you turn on the ignition . The in board management system sends a signal via a coil on the steering column to the key and then the transponder returns a coded signal if it is the wrong one it shuts the car down (it is inductionally coupled so no batterys are requied) These the car cannot programe with only one key (red chip requires red master - blue chip requires two working keys).When you have only one key the dealer has to program the new key into the management system or you have to find a key cutter that can clone another.
Regards ian
