ZeEscort Posted January 24, 2015 Share Posted January 24, 2015 Where would I find the code for a key cutter, as my key for car is so beyond recognition they can't copy & cut so they require the code for the key to make a replacement. All help appreciated. Quote Link to comment Share on other sites More sharing options...
L666JER Posted January 24, 2015 Share Posted January 24, 2015 If the key is that bad and you cant make out what the code should be, the chances are the lock barrels are pretty worn as well. You thought about putting new locks in with new keys etc? You don't want to be stuck in Tesco car park for 2 hours with a failed ignition barrels like I was Quote Link to comment Share on other sites More sharing options...
ZeEscort Posted January 24, 2015 Author Share Posted January 24, 2015 You can't make out what the code is from the Key, as there is no code on the key. As for ignition barrel, if that went I can get around it without any problems (Always carry tools for that sort of thing). The issue I have, is I don't want to have to remove one of the locks to dismantle it and get the code from the barrel pins. Is there anyway I can find out who the original dealer was, as one bit of advice I was given was that they might have the keycode down on record (this came from Ford). Quote Link to comment Share on other sites More sharing options...
L666JER Posted January 24, 2015 Share Posted January 24, 2015 You can't make out what the code is from the Key, as there is no code on the key. As for ignition barrel, if that went I can get around it without any problems (Always carry tools for that sort of thing). The issue I have, is I don't want to have to remove one of the locks to dismantle it and get the code from the barrel pins. Is there anyway I can find out who the original dealer was, as one bit of advice I was given was that they might have the keycode down on record (this came from Ford). It is possible to work out what it should be by the height of each cut in the key e.g 132142, as the deepest cut will be a 4 and the shallowest is a 1 - obviously if its too worn you cannot do this easily. As for finding the dealer I do not know. Don't suppose your lucky enough to have the dealers name on the number plate Quote Link to comment Share on other sites More sharing options...
mick85 Posted January 24, 2015 Share Posted January 24, 2015 If u go ford with log book an drivers license they give u key number Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
mick85 Posted January 24, 2015 Share Posted January 24, 2015 Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
L666JER Posted January 24, 2015 Share Posted January 24, 2015 ImageUploadedByFord OC1422118360.452082.jpg Sent from my iPhone using Ford OC +1 That's what I meant Mick :D Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 25, 2015 Share Posted January 25, 2015 Here's how to read a key, even if worn you should be able to figure it out- 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted January 25, 2015 Share Posted January 25, 2015 Ford dont keep key numbers, original ford dealer may have recorded it, good luck with that one. the problem you will have without much doubt as others have said if you do manage to read the key or get number either rrom dealer or off a barrel, is that the new key wont work on a worn barrel. so either it wont work in drivers door or more likely will jam in the ign lock and wont turn or able to remove from ign barrel Quote Link to comment Share on other sites More sharing options...
ZeEscort Posted January 27, 2015 Author Share Posted January 27, 2015 Key is that worn, no possible way of reading. The trouble is, if I replace barrel I'm also going to have to replace door locks as well. I swear this car has caused me more trouble than my last one lol. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 27, 2015 Share Posted January 27, 2015 An Auto Locksmith should be able to read the code from the locks or ignition directly unless they are all as badly worn. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 1, 2015 Share Posted February 1, 2015 As was advised earlier, if the key is that badly worn you really dont know the state of the barrel. You could get a set from a breakers for a darned site cheaper in much better nick, and to replace the barrels of the doors shouldnt be too difficult a task for a man with a set of tools. The ingition barrel may be of moderate difficulty depending on how confident you are, but even then, you could get one, or two keys along with new barrels - for the price of getting the code of ford and also the key cut. I really wouldnt discount the idea of the barrels though... Phone around a few breakers and see if any of them have a full range - you could possibly get 2 keys and all barrels for a hundred quid or so. Quote Link to comment Share on other sites More sharing options...
Kevinmcdonough Posted July 7, 2019 Share Posted July 7, 2019 Can anyone tell me how to get 2006 Ford Transit key number (tibbi) that is really worn. Thanks Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 7, 2019 Share Posted July 7, 2019 The key should still have enough clues as to the code unless it's totally rounded off.http://carlocksmith.co/28-read-your-ford-car-tibbe-key-code.htmlSent from my SM-G965F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rocinante Posted August 22, 2019 Share Posted August 22, 2019 If you're not in the uk - https://www.motorcraftservice.com/keycode/keycodelookup 1 Quote Link to comment Share on other sites More sharing options...
nicam49 Posted August 23, 2019 Share Posted August 23, 2019 A locksmith will be able to work out the code using special tools (picks) which are available to buy on eBay, but of course they will have the experience to use them. If one lock is too worn to read reliably, then there's always the bonnet lock to get a 'reading' from. 1 Quote Link to comment Share on other sites More sharing options...
nicam49 Posted August 23, 2019 Share Posted August 23, 2019 16 hours ago, Rocinante said: If you're not in the uk - https://www.motorcraftservice.com/keycode/keycodelookup That's a good one! Wonder if there's a European version? nb: name's not Don by any chance? Quote Link to comment Share on other sites More sharing options...
