blackffocus Posted January 27, 2015 Share Posted January 27, 2015 Hello everyone. I am new in this forum. I am planning to connect a subwoofer (and power amplifier) to my original Sony (Focus II, 2007). I think I have the Sony CD132 (one disk, mp3). I managed to make myself the extraction keys, and they work ok. I'd need the pinout of its connector to know if there is some subwoofer output, or I will have to use two Speakers outputs to feed my amplifier. I would like to know if there is some "remote" output to trigger my amplifier. If it is not, I will use +Acc wire. The sticker of my radio shows this model: CDX-5F611R. I'm not sure if this is the 132 model, I will search for the original manual at home. Thank you in advance. Very nice site :P Quote Link to comment Share on other sites More sharing options...
JW1982 Posted January 27, 2015 Share Posted January 27, 2015 The radio's of the Focus MK2 (including the Sony radio's) do not have an output signal or a remote signal for an amplifier. You will have to use the rear speaker output to connect the amplifier. Depending on the type of amplifier you may need a High/Low converter to do this. 1 Quote Link to comment Share on other sites More sharing options...
blackffocus Posted January 27, 2015 Author Share Posted January 27, 2015 The radio's of the Focus MK2 (including the Sony radio's) do not have an output signal or a remote signal for an amplifier. You will have to use the rear speaker output to connect the amplifier. Depending on the type of amplifier you may need a High/Low converter to do this. Thank you very much for your fast reply. My amplifier has High inputs.....I will test them in paralell with the rear Speakers when I found the signals in the radio's connector. Regards and thanks. Quote Link to comment Share on other sites More sharing options...
blackffocus Posted February 4, 2015 Author Share Posted February 4, 2015 I've just installed the sub last sunday. Everything works fine. Incredible improvement. The original Sony sounds very well, and now, with this bass....better. I've found easyly the rear sepakers channels, and connected there my amplifier. Thank you and enjoy your Focus. :) Quote Link to comment Share on other sites More sharing options...
