jimmygixer Posted February 9, 2015 Share Posted February 9, 2015 Fitted rear drop links other day. But i think at least on of them is making a big thump/ snap sound when straightening/ level after a sharpish turn. Any particular way these are to be fitted or what? They dont seem the most secure things in the world for movement at the middle part sits at a angle sort of at each end as it moves. I have the bolts a tight as i dare and looks the same as what i removed. Quote Link to comment Share on other sites More sharing options...
williamweb Posted February 9, 2015 Share Posted February 9, 2015 What is your model?Check the anti roll bar is tight to the crossmember. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
jimmygixer Posted February 10, 2015 Author Share Posted February 10, 2015 What is your model?Check the anti roll bar is tight to the subframe. Sent from my iPad using Ford OC 2003 1.8 TDCI SPORT Check the mounting bolts you mean? Quote Link to comment Share on other sites More sharing options...
williamweb Posted February 10, 2015 Share Posted February 10, 2015 Yes.Also check the bushes that butt up against the crossmember.The drop links should not be fixed over tight. Quote Link to comment Share on other sites More sharing options...
