jeebowhite Posted February 16, 2015 Share Posted February 16, 2015 Nah any corsa can suffer the feacial position... Quote Link to comment Share on other sites More sharing options...
luke.grimbley Posted February 16, 2015 Share Posted February 16, 2015 Heated screen is a must. I've had it since my MK1 LX and wouldn't go without. As far as Ford owning the rights to it.. my mate has just bought a BMW x3, which has a heated screen button, but all it does it set the hot air at the windscreen, which is no where near as good. Quote Link to comment Share on other sites More sharing options...
mgaking Posted February 16, 2015 Share Posted February 16, 2015 Don't modern Fords automatically turn on the heated rear window below a certain temperature? Quote Link to comment Share on other sites More sharing options...
Micro Posted February 16, 2015 Share Posted February 16, 2015 Don't modern Fords automatically turn on the heated rear window below a certain temperature? Or you can set it to via an elm config cable Sent from my Nexus 4 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
theredfox Posted February 16, 2015 Share Posted February 16, 2015 ford must have made fortune over the years with this invention Quote Link to comment Share on other sites More sharing options...
Celticfan Posted February 16, 2015 Share Posted February 16, 2015 Heated windscreens, self parking.......but it's stil a f*****g v******l.! 1 Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted February 17, 2015 Share Posted February 17, 2015 Don't modern Fords automatically turn on the heated rear window below a certain temperature? I think you may be right, it sometimes looks like the rear heated screen is on before I press the button. Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted February 17, 2015 Share Posted February 17, 2015 My 05 Mondeo ST's heated f & r screens & heated mirrors automatically came on when the outside temp was zero, or close to zero. Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted February 17, 2015 Share Posted February 17, 2015 My 05 Mondeo ST's heated f & r screens & heated mirrors automatically came on when the outside temp was zero, or close to zero. Did the lights come on to indicate the screens came on automatically? I'll test it on mine next time we get frost, but I know the lights don't come on which seems a bit misleading if the screen is on. Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted February 17, 2015 Share Posted February 17, 2015 Yes, the switches illuminated as soon as the engine started, the TXS has that feature too, not sure about the Fiesta as we've not used it on a frosty morning yet - will check next time. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 17, 2015 Share Posted February 17, 2015 You can configure the car so under 4.5 degrees they both come on... Quote Link to comment Share on other sites More sharing options...
Philf1 Posted February 17, 2015 Share Posted February 17, 2015 How do you do that? Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 17, 2015 Share Posted February 17, 2015 It's been a while since I did it but it's auto heated windscreen or similar option to set and tick Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted February 18, 2015 Share Posted February 18, 2015 It's been a while since I did it but it's auto heated windscreen or similar option to set and tick Cool I'll have a look, but maybe we don't have that, I think it would be in the menu with the folding mirrors setting but didn't notice it before. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 18, 2015 Share Posted February 18, 2015 Not sure but it's only via elmconfig as opposed to some I spoke to recently who thought you could do this through the instrument cluster Quote Link to comment Share on other sites More sharing options...
south_bound Posted February 18, 2015 Author Share Posted February 18, 2015 I don't really see the point of them coming on automatically. If you can't see through the glass when you start off then you hit the switch and it stops automatically a few minutes later in case you forgot to switch off. Once you are driving, even on a very cold day, the windscreen never freezes again as there is usually a flow of air on the outside to stop the frost from forming, and the inside vents send some warm air that way as well. A couple of times when I have driven from warm sunny weather into cloudy or foggy then the windows can mist up as the colder air hits it and I give it a blast of air or switch on the heated window, but thats not normally at freezing temperatures. Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted February 18, 2015 Share Posted February 18, 2015 I don't really see the point of them coming on automatically. I think it's to save some drivers from their own stupidity. Some people will drive off even if they have very limited visibility, so if the heated screens come on automatically that should reduce the chance of accidents happening. Quote Link to comment Share on other sites More sharing options...
FocusSmudge Posted February 18, 2015 Share Posted February 18, 2015 Completely agree. Defiantly a safety feature more than convenience. Quote Link to comment Share on other sites More sharing options...
Micro Posted February 18, 2015 Share Posted February 18, 2015 And means that you can get in, turn the key, then scrape the other windows without forgetting to do the windscreen! Sent from my Nexus 4 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
