hi Guys , have a problem with a 1.4 2003 fiesta , the radiator fan wont cut in , tried linking the fan to the battery and it works ok , tried bridging out the temp sensor and it wont work , also checked all the fuses and relays all seem to be working also the air con has stopped working ,
any ideas guys ,
cheers dev
Fan not working
Started by DEV, Apr 26 2008 09:06 PM
2 replies to this topic
#1
Posted 26 April 2008 - 09:06 PM
#2
Posted 30 April 2008 - 02:16 PM
any ideas guys ,
cheers dev
mine does similar . . . . only blows hot air regardless of where you set the temperature.
theres a electric solenoid valve at the back right of the engine bay which had to be replaced on mine . . . . . . .
ford would be your best bet, i dont think the parts available anywhere else
#3
Posted 20 July 2008 - 04:29 PM
If it's the radiator fan your talking about, it shouldn't cut in unless your engine starts to overheat! ( so don't expect to see it whirring around like the radiator fans of old did, those were connected at all times with a 'fanbelt' and ran constantly, nowadays they're electric so ONLY work when the engine starts to overheat.)
