Engine Managment Light??2005 Mondeo 2.2 Titanuim X
david kennedy
 Share
hi all,fitted a new egr valve today,along with a refurbed inlet manifold,now have loss/increase power surges,car cutting out on idle,and engine management light along with glow plug light?turning off ignition resets the lights,then after a short drive the same problem occurs...any help to diagnose would be helpful? thnx...
Link to comment
Why was the inlet manifold replaced? Also what problems did the car have before replacing those parts?
Link to comment
hi Stef, decided to replace said parts due to excessive blue/grey smoke under moderate acceleration,original egr valve and manifold was totally gunged u,as was inlet ports which i cleaned out carefully to remove majority of build up,there were no faults before i replaced parts,at 112000, thought it best to replace rather than clean.
Link to comment
Sounds to me like your car might be burning oil, would also explain why it was so gunged up.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
