DavyCookie Posted February 27, 2015 Share Posted February 27, 2015 Hey guys, this has probably already been covered before, but I thought I'd ask anyway, my mk2 passenger side number plate light builds u with rust and water, causing the bulb to stop working, I remove it, clean it all out and replace the bulb, but it has happened quite a few times, I have even replaced the holder itself, no luck. Is this a common problem? Was considering stripping the boot as it seems like it is running into it and I'm pretty sure I'll find a trail, but if it is a simple fix, let me know :) Quote Link to comment Share on other sites More sharing options...
pky Posted February 27, 2015 Share Posted February 27, 2015 The boot handle trim that the number plate lights sit in is connected via 4 bolts behind the boot lid cover. These bolts are connected to the plastic trim and if they have been over tightened they can crack the plastic. Take out the bulb holder and look for any damage to the plastic. Also try removing the trim by removing the 10mm nuts, also you need to disconnect the number plate lights power connectors and the boot button connector. Remove the trim and you will see a foam backing that seals around the number plate light holes. If the trim is undamaged use some silicone sealant around the foam and replace it back. If the trim is damaged in anyway just get another one from a breakers. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 28, 2015 Share Posted February 28, 2015 Replace them with LED units, no place for water to enter them. I fitted some and they're super bright. http://pages.ebay.com/link/?nav=item.view&id=171411631559&alt=web Quote Link to comment Share on other sites More sharing options...
DavyCookie Posted February 28, 2015 Author Share Posted February 28, 2015 Cheers PKY, I'm gonna blame the body shop then going by your explanation, because I had them colour code the strip ): Maybe a bead of tigerseal will do the job? And cheers Stoney871 Quote Link to comment Share on other sites More sharing options...
pky Posted February 28, 2015 Share Posted February 28, 2015 My boot button stopped working. I set about replacing it. One of my bolts was free spinning on the trim as it had become detached from the trim at some point. It had cracked the plastic so water could get into the light. The foam that seals against the car had come away and was unfixable. If yours looks fine then tiger seal should work. I bought a colour coded one from a mark 2.5 from a scrappy and all is well. Quote Link to comment Share on other sites More sharing options...
