Support the club!
ST170 thermostat and housing
1 reply to this topic
#1 Tim ST170
Tim ST170
    Newbie
  • Pip
  • 3 posts
  • Ford Model: 04 Focus ST170
Posted 28 April 2008 - 03:28 PM
Recently upgraded from a 1.6 zetec focus to an ST170, and already the ST170 is giving me problems.
It appears to have a slight water leak from the thermostat housing, and also going from the oil and water temp gauges, the thermostat seems to be stuck open.
How easy is it to change the thermostat on these? There's no haynes manual but is it the same proceedure as on a standard 2.0 engine (as covered in the haynes). I'm aware theres a common fault where an o-ring goes on the 'stat housing causing the small water leak... anyone else had this problem?
Thanks in advance,
Tim.
#2 clarkost170
clarkost170
    Newbie
  • Pip
  • 3 posts
  • Ford Model: st170 '02
Posted 13 May 2008 - 09:13 PM
Thanks in advance,
Tim.
yep ive got the same prob, its common, ive changed the o ring, and it doesnt leak now, you'll need some nmore coolent as it will empty quickly with the plug off but its an easy fix.
