Focus Mk2 Fuse Size Mini Or Micro?
1stghia
 Share
Hi all,
as per the title can anyone give me a clue on fuse sizes in the passenger side fuse box, I only have ato sizes so i can't measure and can't find the info online.
focus 55 plate 1.8 tdci
many thanks :)
Link to comment
It's the 'mini' type blade fuses you need.
  • Like 3
Link to comment
Many thanks, much appreciated :-)
Link to comment
Hi all,
many thanks :)
Yes its the "mini" type it is. you can get small packs online with a few different fuse sizes (ie 10amp,3amp 5amp.......ect) that are very handy to have as spares when you need them.
I included a link below to give you an idea.
http://www.amazon.co.uk/All-Trade-Direct-Mixed-Motorbike/dp/B00904JCSS/ref=sr_1_1?ie=UTF8&qid=1425379274&sr=8-1&keywords=mini+blade+fuses
Hope this helps
  • Like 2
Link to comment
Hope this helps
I was expecting the usual link where you pay £2 for 5 fuses - they really do cost peanuts so it's good to see some priced accordingly.
  • Like 1
Link to comment
the link wasn't for halfrauds though :lol:
  • Like 1
Link to comment
I personally use blow'n'glow fuses.
When one pops it lights up for easy detection.
Smaller packs are available and Halfords do sell them too but only in small packs so work out expensive to do both fuse boxes in your car.
http://pages.ebay.com/link/?nav=item.view&id=271407723647&alt=web
  • Like 2
Link to comment
Hope this helps
Many Thanks for the additional info :D
  • Like 1
Link to comment
lol wow never knew anything like this existed, as it's a pain in the
**** trying to see if one has gone or not, many thanks for the link.
:D
Link to comment
They definitely make diagnosing duff fuses much easier.
Link to comment
as an off chance does any one have any idea what amp fuse to use when using "add a fuse" for a dash cam, I am going to use a 10amp as the original and have a hardwire kit however my add a fuse did not come with a fuse, i thought 3-5amp but as the fuse is added before the hardwire kit that steps the voltage down from 12v to 5v i thought it might need a bigger one???
if that makes sense lol
Link to comment
You may find that the charger has a fuse screwed into the end that plugs in.
If so check the rating of that one and match it.
  • Like 1
Link to comment
The dash cam will probably draw very little power. In theory if your step down transformer is for arguement sake 90% effecient, putting 1A in at 12v will give you out 2.16A at 5v. (if my maths serves me correctly :lol:)
Also putting 2 fuses inline with each other at the same rating does not provide descrimination between which fuse has blown - nothing wrong with doing it but it does prove to be a pain in the rear sometimes.
  • Like 1
Link to comment
lol
Original charger/power for cam is a cig lighter type ...
Input = 12/24v 1amp/max
Output = 5v 1Amp/Max
and the step down ransformer
Input = 12/24 v ??? amps
Output = 5v 1.5amp
I cant open the original charger without smashing it open unfortunately, am mainly looking at adding a piggy back fuse between fusebox and transformer.
Not sure all this is any clearer.
head spinning lol many thanks :)
Link to comment
A 2 or 3 amp fuse is the smallest you will get in mini blade fuses IIRC? I would just go for one of them, 3 amp being more common.
Link to comment
  • 8 years later...
I have a 55 plate ford focus ghia what colour and size is the break fuse
  • Haha 1
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
