dazzee Posted March 6, 2015 Share Posted March 6, 2015 Hi guys, have an issue with headlamp levelling on my 2010 Ford Fiesta titanium 95. First and foremost I presume that the numbers 1-5 around the fog lamp switch is the headlamp levelling, correct me if I'm wrong. Headlamp levelling doesn't work, if I turn the fog light switch from 1-5 etc nothing happens, is it possible that the levelling fuse has blown? If I pull out the fuse will the lights stop working? Bare in mind that there are separate fuses lights etc. headlamp levelling fuse is on the passenger compartment box (fuse number 4. 7.5Amp) Also got an issue with radio/cd/aux buttons. Basically occasionally when I turn on the car and the radio turns on the display doesn't light up and I cannot turn radio down, channel station, turn on CD player etc. this only seems to be when its cold, when car warms up the lights come back on and works. Any takers on what is wrong with it? Doing my nut in, if I turn off ignition and radio is loud, next time I turn ignition on its still set loud and can't turn it down. Any help is welcome. Cheers Darren Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted March 6, 2015 Share Posted March 6, 2015 If the manual says that fuse is only for the headlamp levelling, you should be ok to take it out and check if it has blown, just make sure ignition is off. I don't know about the radio problem though, but I had a similar problem with my 09 Fiesta where the radio screen sometimes wouldn't come on properly and I had to turn it off and on again. Quote Link to comment Share on other sites More sharing options...
dazzee Posted March 6, 2015 Author Share Posted March 6, 2015 I'll try fuse when wife comes home, hopefully it's that simple haha Cheers Phil Quote Link to comment Share on other sites More sharing options...
