The General Chat forum is ONLY for threads which DO NOT fit any other category. If your thread is anything do to with a specific model, it should go in the relevant model club section
Mobius V2 Cam Advice.
jace1969
 Share
Hi all.
Just got me a mobius v2 wide angle dash cam (on its way) and put the sofware in pc ready to set up.
What lead do i need to plug into pc to get pic to set the angle of cam''live picture''
It says it comes with u.s.b video out cable but its got the mini u.s.b and a thin black conector
on the other end.
I have also got the old power lead off my other dash cam and a 5m u.s.b to mini u.s.b to use.
Link to comment
If you connect the camera to a PC with a standard USB cable you can then use the software to set your camera up. Don't forget to set the 180 degree setting to allow the image to be recorded the right way up for viewing as the camera as standard is 'upside down'.
The cable you receive with the camera enables charging, etc.
Link to comment
Just read on a pdf manual that if you plug in u.s.b to p.c with no card its a webcam so can do set up
on the angle in the car and put card in for taking files off etc,is this right.
Also do you do the main set up with card in and i have a few u.s.b cables so these
will be ok as 1 is 5 metre long for car going through a 5v output cigi adaptor.
And i also have old cigi charger off old dash cam already wired in 5v.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
