Tasape Posted March 10, 2015 Share Posted March 10, 2015 Hi so i started to change the bulbs in my car Got to the #Footwell and lo and behold it is a G4 i think, it is flat and has 2 prongs on it does any one know 1. where i can get decent ones from 2 what is the Max wattage i can go for 2nd question i have lights on the side of my door how do you get the Lens cover off without snapping it 3rd question lights on the roof inside how do i change the bulb in this as there is a electronic board in the way on the back of it,( Resolved for this one it is a Non servicable part according to ford) so now i wonder if it can be changed ??? Quote Link to comment Share on other sites More sharing options...
alexp999 Posted March 10, 2015 Share Posted March 10, 2015 If you have a 2013 Focus, it uses LEDs, not bulbs in the footwells... Quote Link to comment Share on other sites More sharing options...
Tasape Posted March 10, 2015 Author Share Posted March 10, 2015 is the G4 the correct one? at the moment the led in there is Weak to say the least Quote Link to comment Share on other sites More sharing options...
alexp999 Posted March 10, 2015 Share Posted March 10, 2015 It is an SMD led, which is soldered on to the PCB of the footwell light unit. I don't think you can just swap it out for a standard one. Quote Link to comment Share on other sites More sharing options...
Tasape Posted March 10, 2015 Author Share Posted March 10, 2015 bummer i was hoping to swap it out guess ill have to find a plan B Quote Link to comment Share on other sites More sharing options...
Rumblestrip Posted March 10, 2015 Share Posted March 10, 2015 Would removing the SMD LED and replacing it with a different coloured LED work? Sent by mind control using Ford OC Quote Link to comment Share on other sites More sharing options...
Tasape Posted March 10, 2015 Author Share Posted March 10, 2015 ill have to give it a try just plain weird, the difference between to 2013 models cant get my head around it some titaniums hav some havent must have been a friday build all the odd bits left chuck in what ever card need finishing for the weekend Quote Link to comment Share on other sites More sharing options...
alexp999 Posted March 10, 2015 Share Posted March 10, 2015 All mk3 Titanium Foci, should have the same light housing with SMD led afaik. Only the titanium X is different, that has an onboard controller, with RGB LEDs, to make the different colours. Quote Link to comment Share on other sites More sharing options...
iantt Posted March 10, 2015 Share Posted March 10, 2015 Some 2 pin connector and some 3 pin connector. Colour changing 3 pin I think. 1 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted March 10, 2015 Share Posted March 10, 2015 Yeah, the red ones are the 2 pin, interior light live feed and the dimming control to the BCM. Multi-color (titanium x) is 3 pin, power feed from ALC (Ambient light control), LIN slave from ALC and ground. Quote Link to comment Share on other sites More sharing options...
Tasape Posted March 10, 2015 Author Share Posted March 10, 2015 I'm just confused to which ones i want im deffo 2 pin but when i see all these ac or dc or ac/dc i dont know whivh i need http://www.ebay.co.uk/itm/G4-G9-Capsule-Bulbs-Day-Warm-White-Led-Light-1-5W-3W-5W-Replace-Halogen-Lamp-UK-/281589660398 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted March 10, 2015 Share Posted March 10, 2015 Your eBay link does only show G4 LED light bulbs. The Focus MK3 footwell lights do not have a G4 light bulb. The footwell lights are a circuit board with a resistor and a single SMD LED. Replacing the stock footwell light circuit boards with a more brighter, more powerful LED which draws a higher current may even damage the Body Control Module. If you want to change the color of the footwell lights you have to desolder the SMD LED from the circuit board and replace it with a different color SMD LED of the same type. I changed the color of the footwell lights on my Focus MK3 from red to Ice Blue. I used the original Ice Blue SMD LED's from a spare original MK3 interior light I had. This way the footwell lights have exacly the same color as all of the other interior lights. Quote Link to comment Share on other sites More sharing options...
Tasape Posted March 10, 2015 Author Share Posted March 10, 2015 Billiant thanks that is a bit beyond my skill level so red it will stay thanks for you help and advice Quote Link to comment Share on other sites More sharing options...
alexp999 Posted March 10, 2015 Share Posted March 10, 2015 This is what you have now, the LED is soldered on to the otherside of the PCB: Quote Link to comment Share on other sites More sharing options...
Tasape Posted March 10, 2015 Author Share Posted March 10, 2015 yes thats right still dont know what i can do tho cant even find replacments anywhere Quote Link to comment Share on other sites More sharing options...
Tasape Posted March 10, 2015 Author Share Posted March 10, 2015 i am assuming then i could not fit any aftermarket lights in there ? Quote Link to comment Share on other sites More sharing options...
Rumblestrip Posted March 10, 2015 Share Posted March 10, 2015 Assuming you can't get spares, removing the original LEDs and replacing with a different colour is a fairly simple job to do. There are loss of different coloured LEDs that will fit in. Might give it a go myself soon when I get the soldering iron kit. I'm assuming the door pocket and handle escutcheon lights have the same kind of lighting? Anyone looked at these? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted March 10, 2015 Share Posted March 10, 2015 As far as I know most of the Ambient Lighting circuit boards are the same. If you want to change the LED on these circuit board you may have to modify the circuit board. The original red SMD LED has 4 small contact pads (1 positive and 3 negative). Most SMD LED's do only have 2 larger contact pads (1 positive and 1 negative). If you want to use a SMD LED with 2 contact pads you have to cut a circuit of the circuit board to avoid a short circuit. Quote Link to comment Share on other sites More sharing options...
Rumblestrip Posted March 10, 2015 Share Posted March 10, 2015 Awwww stuff that then :( Quote Link to comment Share on other sites More sharing options...
Tasape Posted March 10, 2015 Author Share Posted March 10, 2015 i think a How to is needed for this as it it getting very electronic now and i guess beyond the Diy er at home Still it has answered a lot of questions regarding the Mk3 titanium lighting Quote Link to comment Share on other sites More sharing options...
Tasape Posted March 10, 2015 Author Share Posted March 10, 2015 Gonna chat with my nephew who is an electronics wiz he may be able to help. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted March 10, 2015 Share Posted March 10, 2015 I have some spare circuit boards of the footwell lights. I will take some pictures later and explain what needs to be modified to replace the SMD LED's. 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted March 10, 2015 Share Posted March 10, 2015 As far as I remember the size of these SMD LED's is approximately 2.5 mm x 2 mm. 2 Quote Link to comment Share on other sites More sharing options...
Rumblestrip Posted March 10, 2015 Share Posted March 10, 2015 How do you cut the circuit? Stanley blade through the circuit itself? What voltage are the SMDs please? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted March 10, 2015 Share Posted March 10, 2015 I cutted the circuit with a very small, very sharp pair of cutting pliers (Specifically designed for circuit boards and small electronics). Because I used the original Ice Blue SMD LED's from the interior light I do not know the exact voltage. Quote Link to comment Share on other sites More sharing options...
