PaulB1971 Posted March 21, 2015 Share Posted March 21, 2015 Hi, Looking for some help. I have inherited my late fathers Ford Fiesta 1.25 zebec 1998 s Reg (Mk4 I think). It has been stood for about 2 yeas however I have decided to give it the attention it deserves. It has 42k on the clock and is in mint condition. I had a non start issue however found it to be a blown 10 amp fuel pump fuse located under the bonnet. I replaced it and it started first turn of the key. I drove it home from where it was being stored and it didn't run well, a bit chugging. I removed the battery and charged it. Again non start and a blown fuse. I located a grommet under the rear seat and gave the top of the fuel pump a gentle tap and it started up. I left it running to get it warmed up properly as it felt damp inside. I stopped after about 1 hour of idle and it refused to start again literally straight again. I left it for a couple of days and retried it, it started with a little persuasion, however it doesn't idle brilliant, more so when the A/C compressor kicks in. I left it running for ages today and it now won't re start. has anyone had issues with fuel pumps failing. I am thinking it may just be a pressure issue. thanks in advance. Paul Quote Link to comment Share on other sites More sharing options...
AdeMk1 Posted March 29, 2015 Share Posted March 29, 2015 Change the fuel filter, drain the fuel and put in some fresh stuff. After 2 years of being stood the fuel will be stale and fuel filter gunked up. 1 Quote Link to comment Share on other sites More sharing options...
