laumk7 Posted March 27, 2015 Author Share Posted March 27, 2015 Which fuse is it? And does it affect any other part of the car if I do remove it? And which fuse box? In the car or under the bonnet? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 27, 2015 Share Posted March 27, 2015 The port just needs popping out of it's current location and cable tied back out of the way so that it is not easy to access through a quarter window. The wiring does not need modifying, all you are doing is making it impossible to access from outside the car. In the meantime, ask your works Security guys if you can park in a position closer to your works access and ideally under strong lighting and with CCTV coverage. They may even oblige you with keeping a closer eye on it for you if a couple of beers are on offer. Make sure that on entering your vehicle that you check carefully for any tampering to locks/windows etc. and check the car interior for any moved items or anything out of the obvious. Not to rattle you but- Check footwells for 'Lurkers'. A steering lock should dissuade all but the more determined 'tealeaf' Quote Link to comment Share on other sites More sharing options...
laumk7 Posted March 27, 2015 Author Share Posted March 27, 2015 The port just needs popping out of it's current location and cable tied back out of the way so that it is not easy to access through a quarter window. The wiring does not need modifying, all you are doing is making it impossible to access from outside the car. In the meantime, ask your works Security guys if you can park in a position closer to your works access and ideally under strong lighting and with CCTV coverage. They may even oblige you with keeping a closer eye on it for you if a couple of beers are on offer. Make sure that on entering your vehicle that you check carefully for any tampering to locks/windows etc. and check the car interior for any moved items or anything out of the obvious. Not to rattle you but- Check footwells for 'Lurkers'. A steering lock should dissuade all but the more determined 'tealeaf' Ok I'll get my husband to try that later on, and I'll chat to security to make sure I'm right under / in perfect view of their camerasBy lurkers does that mean what I think you mean? :o Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 27, 2015 Share Posted March 27, 2015 I believe the fuse you need to pull is F5 in the passenger footwell fusebox, should be a blue 15a mini fuse. if you have your Owners Manual it would be best to confirm this. Look for the one listed as 'Diagnostic connector'. 1 Quote Link to comment Share on other sites More sharing options...
laumk7 Posted March 27, 2015 Author Share Posted March 27, 2015 Will do thank you x Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 27, 2015 Share Posted March 27, 2015 Ok I'll get my husband to try that later on, and I'll chat to security to make sure I'm right under / in perfect view of their cameras By lurkers does that mean what I think you mean? :o I don't mean to scare you as it's very unlikely, but just asking you to be fully aware and take precautions. 2 Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted March 27, 2015 Share Posted March 27, 2015 Pulling the fuse won't affect the rest of the car's normal operation ability. 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 27, 2015 Share Posted March 27, 2015 Pulling the fuse won't affect the rest of the car's normal operation ability. Indeed, it just means that any device connected to the OBD will not be able to establish a connection to the ECU. Quote Link to comment Share on other sites More sharing options...
Paramanic Posted March 28, 2015 Share Posted March 28, 2015 whats a lurka? this is all new to me as up here we dont get many car thefts and if it is it tends to be a cwappy car that you could pull the doors off Quote Link to comment Share on other sites More sharing options...
Figgis41 Posted March 28, 2015 Share Posted March 28, 2015 Lurka,, i think its a hairy greyhound :D :D :D ASk your security which part of the car park is covered by the camera's and park your car there, when you leave your car make sure the alarm system is fully armed and never half armed and the doors are always dead locked.Its always good to have visuals to ward off thieves as well, yellow coloured steering locks etc,, a mate use to have a wheel clamp on his car when ever he left it on his drive for a while,, big bright yellow thing that basically says sod off and find something easier. Good luck. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 1, 2015 Share Posted April 1, 2015 Easiest way to move the obd is to disconnect the plug behind the port. That's the quick fix and any attempted theft just wouldn't result in them trying to reconnect the port. Must admit I have taken photos of other cars, sometimes because something weird happens lol like I saw a mound of hair on someone's rear wiper.... Quote Link to comment Share on other sites More sharing options...
Marks12 Posted April 3, 2015 Share Posted April 3, 2015 Does the security not patrol the exterior of the building as I work security and the place my company are securing have a strict policy stating that the exterior of the building must be patrolled 24/7 just that most security companies or there clients would insist on external patrols. See as to the CCTV problem in the car park see they would class that area as a low risk areas there cameras would be more focused on the perimeter or the building they are there to secure. But this is only my opinion as I don't know what it is you work at or they are securing. But the place I work at is like fort nox. Defiantly try to park closer to cameras don't think because u park beside your work friends means they won't try anything. If only there was a way to rig the alarm so that when u lock your car if anybody touched it they would get electrocuted 2 Quote Link to comment Share on other sites More sharing options...
Turvey Posted April 5, 2015 Share Posted April 5, 2015 I'm sure there's a law somewhere protecting scum who try to steal cars so this will be illegal :) Quote Link to comment Share on other sites More sharing options...
laumk7 Posted April 5, 2015 Author Share Posted April 5, 2015 I'm liking the idea of self defending cars :d a LOT! Though as you say there's probably some law against them Unfortunately our security are diabolical and I swear even so much as stepping outside is beyond most of them, they're camera happy using their little joystick for control Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
KING KUGA Posted April 5, 2015 Share Posted April 5, 2015 Well bsm have quoted 'over £3k to do that' they can swing lol Sent from my iPhone using Ford OC "Extend the wiring" for £3000.00. Did you ask them where to exactly ? The southern hemisphere ? Pull the fuse to the port for now, as indicated. Round this way the is an epidemic of Fords being stolen using this method. 2 Quote Link to comment Share on other sites More sharing options...
