wertyu2007 Posted March 30, 2015 Share Posted March 30, 2015 Hi all having problems , Focus 1.8 tdci 2002 , cut out a few times on me recently and would struggle to restart , and today cut out and would not restart at all . i ended up having to be towed back by RAC , whilst there the RAC driver sprayed Easy start into the induction pipe and it attempted to start . So im guessing its fuel , every where i read they say Camshaft position sensor but would it attempt to start ? if the camshaft sensor was the problem . He then mentioned it could be the in-tank fuel pump and to look in boot and under rear seats but there is no in-tank fuel pump located in these areas . Anyway , any ideas ? thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted March 30, 2015 Share Posted March 30, 2015 take it to garage to check the fuel pressure on cranking, that will either confirm a fueling supply problem or not, cam sensor not unknown to fail, another one to check is egr valve staying open. so i would check that first by blanking off egr before getting garage involved Quote Link to comment Share on other sites More sharing options...
wertyu2007 Posted March 30, 2015 Author Share Posted March 30, 2015 ok thanks , i initially thought that putting the easy start in the inlet ment cam shaft sensor would be ok but after thinking about it it still could be problem . ill take to garage as last resort ill check a few things myself . Can i remove battery without worrying about ecu etc ? as i need to charge it . ill stick on a £10 cam sensor as its relatively easy cheap job . change fuel filters and check connections etc , thats about all i can do , ill then take to garage . So questions i need to ask are - Can i remove battery safely or should i jump a 12v battery over - Is there a pump in the tank or underneath car inline fuel line to filter , that may have failed ? thanks for help and advice Quote Link to comment Share on other sites More sharing options...
RoadkillUK Posted March 31, 2015 Share Posted March 31, 2015 I can answer the first question, Yes you can disconnect the battery, I'm having similar problems with my 2006. Quote Link to comment Share on other sites More sharing options...
wertyu2007 Posted March 31, 2015 Author Share Posted March 31, 2015 ok thanks . i tried a new cam sensor to no avail . i just found out you can self diagnose on the dash board and came up with DTC codes 9318 9359 but struggling to make sense of them . Quote Link to comment Share on other sites More sharing options...
