Jarhead Posted March 31, 2015 Share Posted March 31, 2015 Hi all, I have recently purchased a '06 plate mk 2 focus. I normally have my mobile phone to the top right of the windscreen so I can see and access it easily. What I would like to do is add power, along with a 3.5mm jack so I can play music and not worry about the phone going flat. The 3.5mm jack I can cover with a extension cable using the aux connection, running through the car to the other side and up the (I hope) drivers side front column surround. The power I thought I could take from the interior light, as in I could cut into the loom before the switch so that there is always a live feed regardless of the light being on or not. Does this sound like a reasonable thing to do? Are there other alternatives? Any help or advice appreciated. Phil Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 31, 2015 Share Posted March 31, 2015 I don't think the light loom has sufficient amps to charge a phone. An option is to piggyback off the back of the lighter socket and run a cable under the dash and up the A pillar. Quote Link to comment Share on other sites More sharing options...
Jarhead Posted April 4, 2015 Author Share Posted April 4, 2015 Thanks for the tip stoney, I overlooked something so simple. Have ordered the parts and intend to split a feed to the location in a few weeks. 1 Quote Link to comment Share on other sites More sharing options...
Wombilly Posted April 4, 2015 Share Posted April 4, 2015 the fuse tap is by far the easiest and safest way. Quote Link to comment Share on other sites More sharing options...
